That's weird that your door will close, but it won't open. My garage door has also been struggling lately too. It will open extremely slow, but it does close at the normal speed. Maybe we should both find a professional garage repair service who can come and fix it.http://www.ajgaragedoorinc.comThat's weird that your door will close, but it won't open. My garage door has also been struggling lately too. It will open extremely slow, but it does close at the normal speed. Maybe we should both find a professional garage repair service who can come and fix it. http://www.ajgaragedoorinc.com
You can't post conmments that contain an email address.
doors do not alter in their openings unless the following has occurred
accident that alters the door opening shape or alters the door hinge position
badly worn hinges
people hanging off open doors or lastly
the sill panels ( rocker panels ) under the door that are part of the door opening and body strength have rusted away under the car allowing the door opening to alter and affect the doors closing properly
when the door stops moving when going down, pull the emergency release handle on the door and then push the door closed by hand. Once it's closed push the emergency handle back so it engages the chain. Open the door and close it a few times to make sure it closes all the way with the motor.
that's no fun removing one with the door closed.. Try everything first make sure key has door unlocked try to open from inside and outside. If not get a slim jim and try that to open door.. Taking door panel off with door closed is not good ..
There is disclosed a method of controlling an automatic door
opening/closing apparatus for a washing machine that includes the steps
of determining whether or not there is an error in an automatic door
opening or closing operation carried out in response to a command to
open or close the washing machine's door; determining if the erroneous
operation has been repeated more than a predetermined number of times
according to consecutive incoming commands to open or close the door;
and when erroneous operation has repeated more than the predetermined
number of times, ignoring a subsequent command to open or close the
door.
1. A method of controlling an automatic door opening/closing apparatus
for a washing machine door, the method comprising the steps of:
opening or closing operation which operation is carried out in response
to a command to open or close the washing machine door;
determining if the erroneous operation is repeated more than a
predetermined number of times according to consecutive incoming
commands to open or close the washing machine door; and in the
event that the erroneous operation is repeated more than the
predetermined number of times, ignoring a subsequent command to open or
close the washing machine door.
2. A method as set forth in claim 1, further comprising the step of: returning the door to the washing machine to an original position in the event that the error occurs.
3. A method as set forth in claim 1, wherein the step of determining if
there is an error in an automatic door opening or closing operation is
performed on the basis of whether or not an inversion occurs in an
open/closed state of the door within a prescribed period of time after
an automatic door opening or closing operation is initiated.
4. A method as set forth in claim 1, further comprising the step of:
clearing the number of errors in the case where the door of the washing
machine has been opened or closed manually at the time of occurrence of
the errors.
5. A method as set forth in claim 1, wherein said predetermined number is 3.
6. A method for controlling the operation of an automatic door
mechanism in a washing machine, said method comprising the steps of: sensing a command to automatically open or close a washing machine door;
sensing whether a failure occurs in opening or closing the door in
response to the command to automatically open or close the door; incrementing a counter indicating the failure; determining whether the counter is equal to a predetermined number; and
failing to engage the automatic door mechanism in response to a
subsequent a command to automatically open or close the door if the
counter exceeds the predetermined number.
7. The method claimed in claim 6, further comprising the step of: returning the door to an original position if a failure is detected.
8. The method claimed in claim 6, wherein failure is indicated by a
lack of a transition between a door open state and a door closed state
within a predetermined time period following entry of the command to
automatically open or close the door.
9. The method claimed in claim 6, further comprising the step of: clearing the counter if the door is opened or closed manually following a failure indication.
follow this to reinitialize
1. Push the “MAIN” power switch to the “OFF” position.
The “MAIN” power switch is located on the instrument panel, left of the
steering column.
2. Confirm doors are closed, lights are OFF, and the key is out of the ignition.
3. Disconnect the negative (–) battery terminal and wait 60 seconds.
4. Reconnect the negative (–) battery terminal.
5. Push the “MAIN” power switch to the “ON” position and wait 3 seconds.
6. Push the “DOOR R” switch to open the right door and wait 3 seconds after the door
is completely opened.
7. Push the “DOOR R” switch to close the right door and wait 3 seconds after the door
is completely closed.
8. Push the “DOOR R” switch to open the right door and wait 3 seconds after the door
9. Push the “DOOR R” switch to close the right door and wait 3 seconds after the door
10. Push the “DOOR L” switch to open the left door and wait 3 seconds after the door is
completely opened.
11. Push the “DOOR L” switch to close the left door and wait 3 seconds after the door is
completely closed.
12. Push the “DOOR L” switch to open the left door and wait 3 seconds after the door is
completely opened.
13. Push the “DOOR L” switch to close the left door and wait for the door to
completely close.
With ignition in the “ON” position and both power sliding doors in the fully closed
position, the “PWR DOOR” indicator on the dash should NOT illuminate.
14. Confirm proper operation of both doors using the dash, B-pillar switches, and the
transmitter button
if unit runs with door open then one of the door switch is stuck closed.there are 2 door switches and they could be assesed by removing the control panel.disconnect wires from top and bottom switches and chkf for continuity.they should be normaly open when the door is open and closed when door is closed.one of them will closed even when door is open.replace that bad one.
the door you open to put the cartridge. If the door is closed and you still get the message, it means the door is not activating the microswitch when the door is closed. There must be a tab on the door which presses the switch.
