window cannot find "C:\programme Files\ECSpecialiesTfilter\shooter.exe" make sureyou typed the name correctly and then try again. to search for a file click start bnbutton and click search
goto start/run and type msconfig and nagivate to start-up tab , then select enable all or disable the one which has shooter.exe , apply and restart. your problem will be solved...
maybe your computer files are corrupted need to reformat that's main some files is missing maybe your computer have a virus your problem is going when you not reformat..
Syncing my iPhone corrupted my PC (XP)Got most fixed with sys restore but can not write to usb drive...
(More)
Syncing my iPhone corrupted my PC (XP)Got most fixed with sys restore but can not write to usb drive A
Hi I asked this question "With html how can you make a bigger, bolder checkmark to put in...
(More)
Hi I asked this question "With html how can you make a bigger, bolder checkmark to put in checkboxes." and you replied "Usually, to make the check mark bigger requires setting the check box to use a larger font. To make it bolder, you need to set the font property for that area to "Bold". But the checkmark html I am using is this " So where from there could I bold it? Thanks again
i have played the game for ages and all of a sudden when i click launch it doesnt happen it seems to...
(More)
i have played the game for ages and all of a sudden when i click launch it doesnt happen it seems to automatically cancel itself. I have since had my comp wiped and re-loaded it etc and the same problem is occuring.
checked pictures I wanted to order, but could not get the order processed!Very frustrateing.Did this...
(More)
checked pictures I wanted to order, but could not get the order processed!Very frustrateing.Did this about three times!
