Question about Frigidaire ATF6000ES Front Load Washer
Frigidare front load washer warranty
How can I find out what the factoryy warraty period is on a Frigidaire front load washing machine? I don't know the model number as I can't find my owners manual and I don't knwo where to find this formation on the machine.
Thanks,
Steve
  • 3 Answers
The usual factory warrenty periord on the Frigidare Affinity washer is 1 Year from date of purchase. You can find your Model number and serial number of your washer on the inside of the door. It is on a white label towards the bottom of the dorr.
Posted on Nov 12, 2007
I have a crack in the top of the washer next to the drawer over the nop what could have caused this
Posted on Mar 16, 2010
My front load washer frigidare door is rusty acsess door is rusted off its only 6 years old
Thank you for your post, debra!
I understand that the front of your Frigidaire washer is rusted. Typically rust is not covered under the warranty and in most cases, the door will more than likely need replacing. Could you please provide me with your model number? You can normally locate your serial tag (which lists your model number) on the upper front interior of the door frame on a front load washer. If you own a top load washer you would normally find the serial tag on the inside of the lid, on the right side. Once I have that information I can provide additional information for your washer. -Matt
Aug 13, 2014 | Frigidaire Washing Machines
Frigidare (GLTF2940ESO) front load washer
Hi , I would like to know how to soak my whites. When it is on a full cycle Thank you
Dec 11, 2012 | Frigidaire ATF6000ES Front Load Washer
Affinity frigidare front load washer won't start. It beeps with message flashing (DR)
Hello zabbster - Typically the DR or DO error code indicates that the door switch is not closed. Make sure that the door lock is completely closed. If the door is closed, make sure the door latch is not broken. If the latch is broken, you may possibly need to replace the door lock switch.
Sep 25, 2012 | Frigidaire Affinity ATF7000E Front Load...
Frigidare washer, model LST6000ESO will not spin water out of the clothes.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jun 25, 2011 | Frigidaire Washing Machines
Daughter washed a feather pillow which fell apart in front load frigidare washer now it wont spin and drain can u help plz?
The drain is plugged...
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 30, 2010 | Frigidaire ATF6000ES Front Load Washer
Describe your Frigidaire GLTF2940FE1 Front Load
Run a cycle with just bleach and detergent, no clothes.
Mar 21, 2010 | Frigidaire GLTF2940ES Front Load Washer
What type and or brand of detergent is recomended
Use only the HE high efficiency detergent in a front load machine and only the recommended amount.
The brand is your choice.
Mar 19, 2009 | Frigidaire GLTF1670A Front Load Washer
How do you change the control motor board on a frigidare front loading washing machine
Access is from the back of the machine. Motor control is on the left side tucked in beside the motor.
Feb 23, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
2,003 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
