Question about Garden
Troy built lawn tractor keeps stalling out while mowing lawn. It starts up again, but mowes for a couple of minutes then stalls out.
    Sergeant:
  • 459 Answers
Check the fuel tank cap
clean the dirt out of top vent
Posted on Mar 06, 2014
I replaced the air filter, I replaced the spark plug, I changed the oil. My Troy Bilt Bronco still keeps stalling out ?
Posted on May 26, 2013
  • 218 Answers
Have you checked your air filter..it sounds like it could be dirty and needs replacing..if this dont help..just comment back and i will get it..and i will help you further..Keith
Posted on Jul 08, 2009
SOURCE:
Have a John Deere lawn tractor. It starts and runs fine in forward gears, but when put in reverse it stalls . Any ideas what it may be? Could there be a faulty limit switch of some sort?
does it stall when mowing in reverse?
its supposed to do that
look for an over ride switch or button some the key has to be in reverse position to mow
check owers manual
Sep 24, 2013 | Garden
Lawn mowers
Maybe it need a spark plug
May 08, 2013 | Garden
Stalls When engaging the blade clutch
Check that the blade brake is disengaging. Slip belt off blade spindles and check that they spin freely. Check underside of deck for clogged grass, ropes, wire, etc.
May 07, 2012 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Cannot have blades engauged when in reverse mower stalls
You are right, the mower has a disconnect for the pto when you try to mow in reverse. You need to turn the key to the mow in reverse position, and now you can mow going backwards.
Hope this helps, Matt
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Dec 11, 2010 | Toro LX466 22HP Lawn Tractor 13RT61RH244
I have an old Cub Cadet lawn tractor model 2155, where the PTO clutch stops working after about 15 minutes of mowing. It will re-engage after it stops, but will only mow for a couple hunder feet before it...
I have a Cub Cadet 2155 lawn tractor that mows great, purchase in 1999, however it started heating up about an hour into mowing and then I have to shut it down until cools. I have replaced the air filter & that did not work ?
Help.......Thanks
Aug 10, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Hope this isn't a double post. Yardman push lawn mower rear bag starts right up and then mows about 6 rows before stopping. I start it again and it mows about a row and stalls. I let it sit for about an...
it sounds like you may have a vapor lock on your fuel tank   there should be a diaphragm on the inside of the fuel cap  that lets air in but not out   it may have an air hole clogged  take the cap apart if you can and clean it real good and put it back together   if that is not it  then the float in your tank may be stuck   or a fuel line filter may be clogged
Nov 07, 2009 | Toro Lawn Mower With Toro Power Tools
Cub Cadet 2165 Mower Shuts Down
did you happen to check the gas cap if the vent is clogged in it ? when it stalls loosen the gas cap and see if it makes a whoosh sound
Aug 31, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
420 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
