Televison & Video Logo
A
Anonymous Posted on Oct 04, 2014
I have a hisense 55" lcd and there seems to be some discoloration sometimes when there is dark colors and appears vertically. Usually looks like a greenish color and is not confined to any certain spo
I have a hisense 55" lcd and there seems to be some discoloration sometimes when there is dark colors and appears vertically. Usually looks like a greenish color and is not confined to any certain spot on the screen. It is bit difficult to explain. There is also vertical lines on the left hand side of the screen that are not a solid color but are just noticeable if looking at it. The T.V use to turn off on it's own sometimes when watching but recently instead of turning off it has been turning on in the middle of the night. It does not have a wake timer but does have a sleep timer. The sleep timer is sometimes used but was not the reason it was turning off before. Also when it does turn on by itself it is at random times of the night. The main problem is the picture though it is not terrible however it is ugly at times and when close to the tv I can really see the vertical lines. It is not just the dark colors but is random on the screen.
Level 3:
Top Expert:
  • Televison & ... Master 76,851 Answers
  • Posted on Oct 05, 2014
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14994637
Points
237762
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
5 Related Answers
Anonymous
  • 98 Answers
  • Posted on Feb 06, 2009
SOURCE: Vertical lines in LCD tv screen
Need to check the two things.
1st -- need to exchange T-con Board.
2nd -- need to exchange the cables between T-con & LCD panel or
between T-con & Main(LVDS cable)
Anonymous
  • 814 Answers
  • Posted on May 23, 2009
SOURCE: Insignia 27" lcd tv vertical colored lines across screen.
This television, appears to have had a failure in the mainboard. This is the board that controls the video functions and sound functions. The unit should be taken or sent in to a service center for testing and servicing. The service center will have all the correct service information to determine the problem for you. You can call Insignia customer support at this telephone number 1-877-467-4289. You can also got to the customer support website at www.insignia-products.com. Go to the support section and ask them for help on how to get service for your television. I hope this information helps you with your problem.
Anonymous
  • Posted on Jan 20, 2010
SOURCE: Vertical dark line down screen
http://www.avforums.com/forums/sony-owners-forum/1165140-faint-lines-kdl32s5500.html
I have also experienced the same problem on two occasions, but my Sony TV KDLV3000 has actually been backwards and forwards on three occasions to be repaired. I have had a new control unit and will be having a second screen replacement shortlymad.gif. I have contacted my local Sony Centre and they have stated that they will only replace the TV if there are THREE IDENTICAL faultsfacepalm.gif.
COME ON SONY CENTRE GET YOUR ACT TOGETHER AND TAKE A NOTE FROM JOHN LEWIS THERE CUSTOMER CARE IS SECOND TO NONE.
Not sure I'll buy a Sony again after this experience having been a loyal Sony customer for a number of years, will probably look at a Samsung or LG next time.
Testimonial: "Thanks for your comments. Very useful."
Anonymous
  • 10594 Answers
  • Posted on Feb 27, 2010
SOURCE: I have a 42JC2D TV. Vertical color bar lines
It is hardware issue related to LCD Panel (screen).
Regarding fixing it, it depends if you are handy with electronics stuff repair and can replace circuit boards in tv etc then please check T-Con (lcd controller board) on top center position at rear of lcd panel, this board would be covered with metal shield. Need to take off back cover of tv to get access to T-Con board. If T-Con board does not solve lines problem of screen then LCD Panel is bad and will be replaced.
If you fee uncomfortable doing so then repairman option is better choice.
Hope this info will help you.
Thanks.
Anonymous
  • Posted on Mar 22, 2010
SOURCE: Vertical colored lines on left half of screen.
I had this problem on a 37" Viewsonic LCD. Pulled it apart and through a process of elimination, I traced the problem back to a small board with several flat white ribbon cables coming out of it. The board was near the top center of the screen and under a ton of other equipment requiring almost a total disassembly.
This small board was clean but I noticed one of the rubber standoffs had slipped down and was making contact with one of the outputs running to the LCD. It also happened to be the output running to the section of the screen with the problem.
I postulated that the sticky glue on the rubber standoff may have just enough conductivity to cause a problem. Moved it so that it was no longer touching anything electrical and then reassembled the TV.
Afterwards, I turned it on and was pleased to see the problem has gone away! If you're having the vertical line problem, then maybe this could be your problem too, especially if you have a Viewsonic since it could be a manufacturing defect.
My Hisense 40" 40D36PN has an intermittent thin black vertical line in the middle of the screen. What is the cause?
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size
Samsung contrast problem
Faulty T'Con board. If you wish to get some details; check the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
How do I fix the picture?
there is a T con error please replace the T con in this condition
Why does my TV show discolored vertical bands and can I fix it at home?
The T-con board controls the picture elements on the screen. Usually replacing this board will solve the problem. If you can touch the screen and the lines disappear and later reappear, that says the screen itself is defective. The only fix is to replace the entire screen.
7helpful
2answers
55 inch hitachi lcd projection tv has yellow and purple blur near the center of the screen
This, sadly is getting to be a very common problem with all Projection LCD TV's
Colored Blotches on an LCD Projection TV are usually caused by defects or marks on filters or lenses on one of the LCD panels themselves which are all located in the light engine (or optical block) First confirm that the lamp or main lens is not discolored by removing the lamp (unplug set and let cool before removing!) and visually inspecting the lamp itself and the lens that it shines onto. The light engine is an expensive part ($600-$1200) to replace and requires major disassembly. Have a tech confirm-Get an estimate -Be sure to vote/rate me if this helped Thanks!
1helpful
Acer AL 1912 (black) resolution issue
[u][b]LCD Monitor Shadow Effect[/b][/u]
This problem is best described as the LCD monitor "Shadow Effect".
The solution to this very simple. No software or hard ware changes required.
The cables that are connected to the LCD monitors are causing the problem. Its also called as electromagnetic noise or electrical noise.
[u][b]Solution: [/b][/u]Keep the two cables - (power cable and moitor display cable), that are connected to the LCD monitor as far away as possible with each other and also away from other electrical cables.
Thats it. Your shadow effect is fixed.
Thank you.
Pink discoloration and vertical lines in light areas
Possibly a form of flare caused by including the light source in the image.
Dark Grey Vertical Bar
1. try connecting laptop to an external monitor and check if this vertical dark gray bar appears. if yes it means video is the problem. you need to boot in safe mode then uninstall the video driver. boot to notmal mode then download and install the latest video driver. if still same problem then replace video card. if video is built in with motherboard you need to replace motherboard.
2. when the vertical dark gray bar did not appear in the external monitor then it means issue is with the LCD panel. Do this turn off laptop. press and hold D key then press Power button at the same time or Press and hold on the Fn key then Power button check if the test will run. Color displays full screen when you keep pressing on N key when the colors appears check the vertical dark gray bar if still exist in the test, this means LCD panel and LCD cable needs to be replaced.
Colored vertical lines
It is a tossup between a bad LCD panel and the logic board. The only way to tell for sure is to change out the logic board or have it tested on another unit. Checkout www.lcdrepair.us for instruction videos on that unit as well as parts.
http://www.lcdrepair.us/Installation.html
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
