Question about Maytag MSD2756GES Side by Side Refrigerator
Ice dispenser When I press switch for ice, ice falls into the chute, but the flapper door does not open, and ice collects in the chute.
  • Anonymous Feb 04, 2008
    I have the same probplen and know of two friends who also have this problem.
I fixed it by replacing the solenoid that operates the flapper door and the flapper door. They came as a kit and both were broken.
I still have a problem which is a bad circuit board. I can't switch from ice to water. I am stuck on ice, so I have not bothered to fix.
Posted on May 12, 2008
I've had this problem, too, but find it worse in the summer, high humidity (I live in Dallas, Texas) and high use.
Posted on May 11, 2008
    Problem Solver:
  • 14 Answers
Make sure that the flap is sitting in properly. if it is and problem still happens then i'd say that its a design fault
Posted on Apr 10, 2008
Can the flapper for ice be replaced?
Refrigerator model number? ice chute door replacement
26177815-rm0wrikgpdq1hfoxb3io2p34-3-0.jpg need your model number for the correct part Dispenser Door 8201756
APPLIANCE 911
Apr 27, 2016 | Refrigerators
Lg lmx25984 ice chute flap will not open automatically
On Mine, the solenoid connection fell off that allows the ice to dispense, Thank you so much!
Aug 04, 2012 | LG LMX25984ST 24.7 Cu.Ft. French 4-Door...
Ice Dispenser keeps getting frosted over and not dispensing ice
The problem your having is that the door in the dispenser chute isn't closing completly and warm air is coming in, clashing with the freezer and the moisture in the warm air freezes and collects right there in the chute causing the ice build up. The more common parts that may cause this is the door flapper being bad or damaged, flapper soleniod, which helps the flapper doofr get a good seal, and electronic board on the dispenser itself.
May 24, 2012 | GE Refrigerators
I have a GE SS25ksta side by side refriderator. The ice maker makes ice, but the chute jams without fail. It is almost as if the ice doesn't weigh enough to push open the flapper arm at the bottom of the...
there's a solenoid that opens and closes the shute or the flapper.the part number is WR62X10055 and it's around 25 dollars.check around the plastic frame that holds this section of the dispenser in place,i'm pretty sure the frame pops off,you might need a putty knife or thin screw driver to pop it off,then you can get at the rest of the parts to change out the solenoid.it's self explanatory and easy to change it out once you pop off the outside frame piece
Jan 16, 2011 | GE GSS25KGMBB / GSS25KGMWW / GSS25KGMCC...
WATER DRIPPING IN DISPENSER TRAY DUE TO ICE MELTING AT FRONT OF DISPENSER
Hi Don,
Typically this occurs when the dispenser door does not close all the way.
The dispenser door is located in the freezer door in the chute that the ice dispenses down.
With the freezer door open shine a light up from the outside and look down into the door from the inside. If you see light around the door flapper, you will need to replace the dispenser door, if there is a large gap between the dispenser door and the chute you will need to replace the mechanism that controls the door.
Apr 18, 2010 | Electrolux Refrigerators
Ice dispenser door not working
The flapper door is operated by a solenoid which opens the flapper. More than likely the solenoid is bad, but, it could also, be the control board.
Jul 01, 2009 | Whirlpool GS5SHAXN Side by Side...
GE Profile 26.6 cu. ft. side by side is frosting in the shoot
Oddly enough, the problem is with your ice dispenser. What happens is that the door at the bottom of the ice chute is probably not sealed. This is likely because there is a solenoid that is supposed to hold that door open when you push your cup against the dispenser arm, and THEN, close it again when you release. If the chute door is not sealed, warmer, moist air from outside the refridgerator will be canstantly drawn up the chute where the moisture will freeze as frost. Gradually, this frost builds up in the chute until there is no longer enough room foir the ice to fall. You can usually look up at the chute from outside and see that the door is not sealed. In my case, I left it unsealed because the door would not open to let the ice out. It took me about 3 months to figure out that this was causing my frost-clogging problem. The solution is to replace the solenoid that is supposed to open and close the chuite door. If you remove the despenser panel, you will see that this solenoid is probably all rusted up and not working. The following link will allow you to enter you model number and see a diagram of the offending area. http://www.pcappliancerepair.com/model-display.php
Jun 10, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Icemaker - flap won't open, cubes collect in chute
the actuating paddle that you are depressing to dispense ice actually pushes the door open at the top of the dispensor, soundsas if thered an issue withthe actuator arm
Nov 18, 2008 | Frigidaire FRS26R4A Side by Side...
Ice dispenser chute
most flaps have a solinard that opens and closes the flap,if you can replace or get in there to lube it you should me ok,let me know more-mike
Sep 29, 2008 | KitchenAid Superba Architect KSCS25INSS...
Maytag MSD2756GES Side by Side Refrigerator Logo
334 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
