Question edited for clarity, 'full make model (what is is)' spelling of maker and all the missing letters. Please don't type in all CAPS. Question moved from Cameras category. Duplicate question deleted. Refresh page to see your question.
Make sure the polarity of the batteries is correct.
Contact Rayovac Support for help and warranty replacement.
Pretty much impossible unless you fish it through with a snake wire. You don't say why you are trying to do this? Just use a standalone rechargeable LED light or lantern.
you can google your question for answers.try it
About 7,790,000 results (0.50 seconds)
A big hint if you can't or wont google your question.
It tells you on the top of the lantern if it is the 6 volt type - you unscrew the large knob, and the base will come off when it is unscrewed completely. To change the florescent bulbs, you unscrew the small knob.
Since batteries and bulbs are new/ok, check for a bad connection. In older version using 4 lantern batteries, open the battery compartment by unscrewing the knob on top of lantern. The lantern bottom comes off once unscrewed (of course you did this to change batteries). There is a "C" clip on the lantern center shaft; remove this by prying with screwdriver or with pliers. Carefully raise the battery contact plate and check slip-on wire connections. Clean as needed (Scotch-Brite works well) and reconnect. Squirt some contact cleaner in exposed switches, work switches back and forth. Inspect circuit board for obvious corrosion or damaged parts (this damage may "total" the lantern). Re-install plate aligning grooves with ribs. Install batteries and test.
