Question about Proscan PS36600 36" TV
No Sound We had this tv wired with a surround sound system, that has been removed. I can access the audio options through the menu, but cannot unmute it - I've tried using the two options with speakers in the audio output and still no sound.
Have you checked the switch at the back of the set (very small) that is marked internal or external speakers
Posted on Dec 31, 2007
I was wondering if my tv has any of the out puts needed to set surround sound up on the tv part
Go into the set up/ menu screen on your TV. Look for audio set up to see if there is an option for surround sound output. If it doesn't have a surround sound output option, it most likely doesn't have surround sound on board. You will need to get a home theatre system (which will probably be much better anyway).
Nov 04, 2013 | Samsung LN46E550 - 46" Class 45.9"...
Hi how do I get surround sound coming from my tv
A Samsung home theatre system can make watching movies at home like going to the theater. Proper setup is essential to get the full benefit of the Samsung system, which is available in 5.1 and 7.1 channel surround sound configurations.
Typically the final step in setting up any home theater is connecting your TV to your system.
Like most home theatre systems, your Samsung home theater receiver will allow you to plug all of your components into it, meaning you only have to run a few cables to connect your television to your system.
Make sure your playback devices are properly connected to your receiver.
Whatever playback devices you use, make sure they are plugged into the appropriate inputs on your receiver.
DVD and Blu-ray players, satellite boxes and cable boxes should all be plugged into video inputs, and CD players should be plugged into audio inputs.
Your receiver will have labels on the back panel indicating into which input you should plug your devices.
Connect the video out to your TV's video input. Make sure you use the correct cable to make the connection. For newer receivers, the connection will likely be either HDMI or component.
If your receiver has an HDMI output, use an HDMI cable to connect the receiver to the HDMI input on your TV.
If your receiver uses a component output, use a component cable to connect your receiver to the component input on your TV.
Connect the audio output of your TV to one of the audio inputs on your Samsung receiver if you want to output your television's audio through your home theatre system.
Most recent TVs will either use an optical cable or a digital coaxial cable to connect to the receiver, allowing you 5.1 channel surround from your television.
If you have an older set, you will likely have to use standard RCA cables.
Turn on your receiver and press the "Setup/Menu" button on your receiver's remote.
When "Input" appears on the display, press the right arrow key on your remote to select TV from the list.
After selecting TV, press the up or down arrow keys on your remote to select the audio input jack into which you have plugged your TV's audio cable.
Press the "Exit" button on your remote to exit the setup menu and lock in the settings.
Samsung home theatre system owners guide download
If you're not an electronics junkie, hooking up your surround sound can seem daunting.
There are so many wires and settings that it's understandable why some people might rather pay someone else to do it for them.
But you can do it yourself as long as you make sure the speakers are positioned correctly; the wires are not only plugged in all the way, but plugged into the right places; and the settings on your television and amplifier are set up correctly.
Check to make sure your surround-sound speakers are correctly installed.
Locate the test function on your surround-sound remote control or amplifier panel to do this.
You will know your speakers are hooked up if sound comes out of each speaker during the test.
Make sure your audio cables are hooked up properly.
Make sure the audio cables running from your television to your amplifier are plugged in correctly. The red and white wires should be plugged into the "Audio Out" spot on the back of your television.
Those same red and white audio wires should be plugged into one of the "Audio Input" spaces on the back of your amplifier.
Turn on your television.
Locate the "Menu" button on either your television remote or your television set.
Scroll through your options until you find "Audio Mode" or a similar naming convention.
Select it.
Scroll through your options until you find "Digital Audio Out," or a similar naming convention. Choose it.
Scroll through your options until you find "Dolby Digital Out." Select that option.
Power your surround-sound system on.
Make sure you have the correct audio input selected.
After the correct audio input is selected, make sure you actually have the Dolby Digital aspect of your surround sound system turned on.
The default for most surround-sound systems is the standard two-channel, stereo output.
Set up a home theater
Aug 07, 2013 | Samsung Ht-E355 330W 5.1 Channel Home...
Getting tv in surround
you need to plug rca cables into the audio out of your tv providing it has them then go to the setting menu in the tv go into the sound options and turn on surround sound
Jul 01, 2010 | Curtis DVD5091 Theater System
Connect creative 4.1 speakers with laptop at time 2 speaker work
i assume ur mother board supports surround sound an ur using windows os. go to control panel - sounds and audio devices - speaker settings-advanced - speaker set up with the drop down menu. select surround sound - apply - ok.
if ur using surround audio drivers like realtek, etc. the settings console should have somewhat similar options like audio input/output (I/O) options. select surround sound speaker setting and configure which audio port should be audio output ports. driver settings can be accessed from control panel too. to access control panel click on start menu there u'll see the control panel menu.
Mar 13, 2010 | Creative Labs Audio Players & Recorders
No audio
went into setup, tv and kept hitting the mute then unmute it finally took. Not sure what was wrong with it since I had already done that several times. The two audio outputs on the side of the tv do not work like it says in the manual for surround sound. Its definitely a cheap tv.
Jun 21, 2009 | Olevia 227-S11 27 in. LCD TV
I have a 32 inch LG4000 with built in DVD. Poor Audio
You are not asking too much and I believe that you can solve this problem in a menu option on your TV. Most systems designed to work with surround sound and/or by itself have some audio options that are designed to simulate or work in concert with surround sound. Start by looking around your TV menu options for something labeled digital audio compression or something like it. Sometimes there will also be a function in a menu to "simulate" surround sound attributes. Try to change these to factory or default settings, and if that still sounds the same try changing the settings around until you hear more accurate audio.
Apr 08, 2009 | LG AP-40SA10B TV Speakers
No sound coming through
If the DVD player is seperate from the surround system and hooked up to the tv. You should have a wire from audio out on the tv to the audio in on surround sound. Some tv require you to turn off tv speakers inorder for it to be routed to the audio out. In which case you can do this in the menu.
Mar 14, 2009 | Audio Players & Recorders
Surround sound hookup question?
It looks like all you'll need to do is hook up audio out from DirecTV to audio in on the surround sound system. Sony has an interesting hookup recommendation guide on the product support site:
That should give you the connection options. The short answer, though, is to connect the best audio out from DirecTV to an audio in on the surround sound and then choose that option in the surround sound system when you want to watch TV.
Jul 16, 2008 | Sony DAV-X1 System
Connecting surround sound system
get a reciever and then get componet cables then hook it all up through the hdmi cables
Jan 22, 2008 | Sylvania 6727DF TV
Connect PS3 for playing/viewing blue-ray thru surround sound
Connect the PS3 to your TV with the hdmi cable and to the surround sound system with a digital optical cable, then set your PS3 to output sound through the optical port (through the sound options menu) and you're good to go!
Oct 27, 2007 | Sony DAV-HDX500 System
Televison & Video Logo
180 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
