Question about Lexmark X5270 All-In-One InkJet Printer
Paper jam - misfeed
Pulls down on the right - i have tried every thing i could - can i remove the spool to realign? any ideas would make me so happy!
lexmark x5270 (allinone - discontinued product)
  • 1 more comment
  • The Warden Dec 22, 2007
    I have the same problem. It appears that the roller is positioned so far right that it appears almost impossible for it to feed straight. I don't seee anything obvious that causes the paper to misfeed.
  • Anonymous Mar 23, 2008
    My printer won't feed at all unless I force the page in. It appears the feed rooler is not grabbing the paper. I don't see a way in to see if the spring loaded guide is not putting tension on that rooler to feed that page. I am frustrated. This is a decent printer. Any ideas folks?
  • Anonymous Oct 25, 2008
Mine also miss feeds to the right and jams. As far as I can tell it's a problem with the basic design of the printer. I personally am not thrilled as I will never likely be able to afford sending this thing to the manufacturer to be fixed. All in all that's probably for the BETTER as I would be "red stapler"* homicidal if I actually did manage to scrape the money together to send my printer in just to get a hold of someone on the phone the next week who get's crappy with me and tells me to *&#$ off they will not fix it or pay to send it back much less reimburse my shipping and handling. Stupid me for buying this printer. And stupid me again for buying ink refills for it yesterday cuz I hadn't used it in so long (cuz it's always broke) I forgot the paper jams all the time and dosen't print straight even when it does load. I'd really like to sit down with lexmark designers and say "What the hell? You ripped us off! How many of these printers did you sell??"
Posted on Jul 13, 2009
When you find out--please let me know--mine is doing the same
Posted on Mar 17, 2009
How to clear and avoid paper jams: To clear the paper path: 1 Pull firmly on the paper to remove it. If you cannot reach the paper because it is too far into the printer, lift the scanner unit to open the printer. 2 Pull the paper out. 3 Close the scanner unit. 4 Press check. 5 Reprint any missing pages. To avoid paper jams, do not force paper into the printer.
The Lexmark X7500 Series User's Guide will be able to give you more detailed instructions on how to troubleshoot paper jams and misfeeds on your printer. You can download the user's guide from the Lexmark website at and go to page 177.
May 10, 2011 | Lexmark X7550 InkJet Printer
Hope this may help;
Aug 29, 2008 | Sharp AL 800 Copier
Remove Misfeed B Fusing Unit Error- After 1 page is printed
just open the printer and check for any dislocation of the sensor or levers.
Apr 26, 2008 | Ricoh Aficio AP3800C Laser Printer
My sharp 2300-n notified me of a paper misfeed. After clearing all misfed paper, the copier is still telling me there is a misfeed, and is not allowing me to print or copy. Suggestions?
Make sure that all of the paper jams are removed. Check every available cavity, including your paper trays. Pull each tray out and make sure there are no jams right out of the paper trays. Sometimes a piece of paper can become lodged where you cannot see it.
If you are positive there is no paper stuck in the machine, then you have a paper-path sensor that is either dirty or faulty.
Oct 29, 2010 | Sharp MX-2300N Color Copier
Paper keeps shifting during loading and eventually gets jammed every time
Seems like the rollers are either dirty, or worn out. Probably the latter.
“Paper jams” on page 68
“Paper or specialty media misfeeds” on page 68
“Printer does not feed paper, envelopes, or specialty media” on page 69
“Banner paper jams” on page 69
Paper jams
Is the jam in the paper
1 Press to turn off the printer.
2 Firmly grasp the paper, and gently pull it out.
3 Press to turn the printer back on.
Is the jam in the printer? To automatically eject the paper:
2 Press again to turn the printer back on.
The paper automatically ejects from the printer.
To manually remove the paper:
If paper or specialty media misfeeds or skews, or if multiple sheets feed or stick together, try the following solutions.
Check paper
Use only new, unwrinkled paper.
Check paper loading Load a smaller amount of paper into the printer.
Load paper with the print side facing you. (If you are not sure which side is the printable
side, see the instructions that came with the paper.)
See “Loading various paper types” on page 21 for information about:
Maximum loading amounts per paper type
Specific loading instructions for supported paper and specialty media
Remove each page as
it is printed
Remove each page as it exits, and let it dry completely before stacking.
Adjust the paper
Adjust the paper guides:
When using media less than 8.5 inches wide
To rest against the edges of the paper or media, making sure it does not buckle
Jul 22, 2010 | Lexmark X2500 All-In-One Printer
Red blinking light
Hi, this is not a cartridge related problem. As you have written, it is related to the paper misfeed. When removing any future paper misfeeds, always take extra caution as not to destroy the paper sensor. If it jammed near the paper tray area, first open the right cover to see the paper, the try to pull it slowly till it comes out. Never try to force it out as you may tear a small piece which will show you that a misfeed is still on. If it does tear, carefully remove it until its out. If it jams on the fusing unit, release the side levers on the copier or turn the green rotating lever on the front which appears when front cover is open until it ejects it out.
If you are sure there is no jammed paper, make sure the spring on right side of fusing unit, where there is a sensor is retracted to its position. Good luck pal.
Jun 05, 2010 | Sharp AL 1631 Copier
Ricoh Aficio CL3500N printer phantom misfeed
It seems that the sensor is having dust or toner settled upon it. Kindly remove the toner and clean the residual toner. Take a hard stock paper and give one copy command and push it while it tries to pull the paper. Paper misfeed is not the same as paper jam. Paper misfeed refers to the blank paper tray and paper jam refers to paper which has been taken from the tray and now inside the unit.
May 19, 2010 | Ricoh Aficio CL3500N Laser Printer
Sharp al-1631 misfeed light will not go out
This usually happens when a sensor that detected a paper jam has not reset itself after removing the paper. Make sure that when the jam was removed - all the paper came out and there is/was not a small piece missing that could have been left behind in the copier and is hiding somewhere. If you are sure the paper has all been removed then what could have happened is when the jam was being removed it could have caught on one of the paper sensors. This could pull the little flag that activates the sensor out of place - giving a false paper jam message. there are only a handfull of sensors in the paper path. remove the paper tray and make sure there is no paper stuck behind the tray or in the cavity where the tray goes. look and follow very closely the path the paper takes - look for any sensors/flags the paper would avtivate and make sure the flag moves freely and is not lopsided.
Make sure you also try unplugging and replugging the copier from the wall.
Hope this helps
May 19, 2009 | Sharp AL 1631 Copier
Misfeeds paper pulls to the right--says paper jam-no jam
there could be a paper jam or some paper still inside.
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Mar 17, 2009 | Lexmark X3350 All-In-One InkJet Printer
Lexmark X5270 All-In-One InkJet Printer Logo
189 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
