Watches Logo
m
mary Posted on Oct 05, 2014
Where can I get an owners manual for field and stream tent, model 36002
I need a new watchband
So go online, find your nearest Field & Stream dealer and order one of your liking. You need to post on fixya for that??????
Trying to find out if Field and Stream clip on watch #F144CLPK is water resistant? Any help is appreciated. Thank you.
no picture? ok ...
most watches are water resistant, but on a limit time and at certain depth.
i have saw picture of field and steam on the internet, and i will not recommend them for use on water situation.
Hi on my field&stream F196gkbs the sweep
This is an early warning sign to get the battery changed .The watch should still keep time for a couple of weeks.
2answers
Compass dial turned opposite direction
you might be able to reverse the poles back to normal with a magnet but be careful not to scratch face or get it closer than you need to to the insides of the watch.
Chane the batteries
good day dear cherished customer.
my name is eltoyosi and am here to help you.
You an change the batteries of your field and stream wrist wach by going to the back and gently getting the flip covering the backside of the wrist watch and there you will see the battery which needs replacement, you know replace the old battery with a new one recommended for field and stream F116GWBS
thanks
hope to hear how it went.
1helpful
Missing hinge pins
You will have to get a complete clasp assembly, which will have to be ordered from the factory that makes that model. If the clasp assembly is not available, A jeweler might have that part or be able to repair it for you.
Need replacement strap for F33FOBGKVK
Try these guys; http://www.wristwatch.com/contact.aspx They sell most of the new Field and stream models and should hopefully be able to help Hope this helps, please post again if not :)
Field & Stream Mens Watch, F42GUBS
Take the watch to a jeweller. They should have all the batteries and seals and tools necessary for the job, and it rarely takes long or costs that much. you could probably manage yourself, but getting the seals especially is easiest through a jeweller anyway. Most likely reason for any watch to be not working is the battery, the next would be moisture inside - normally visible round the screen/face. always worth replacing the battery to see, unless the watch cost less than the battery, which it didn't. Hope this helps :)
Top Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Watch Expert? Answer questions, earn points and help others
