Device driver installation failure. Your OS may not be compatible with drivers of HDD or your HDD needs driver to be downloaded from manufacturer's website.
There are a few possible reasons to get the USB connection error. You could have a bad USB cable, a bad port (on the computer or the sewing machine). If you are using a USB hub, try a direct connection. Try a different USB 2.0 cable (type A to type B) of 6' or less in length connected to a different port. You might simply be opening the program before the driver is completely installed. Wait a few minutes after turning on the sewing machine; look for the New Hardware Found message disappear indicating that the new driver has been associated the USB device. Usually the new hardware found is announced with a beep.
If you are connected to a USB 1.0 port, you need to turn off the computer, connect the sewing machine's USB cable to both devices and then turn on the sewing machine. Then turn on the computer and wait for the driver to be installed completely. (The first generation USB protocol was not plug and play. It only recognized devices on restart/boot.)
To check if the driver for the sewing machine is found by the computer, open the Device Manager. Expand the Human Interface Devices section. If the entry for the CE-350 has an exclamation point or a red x, the driver hasn't been properly installed. If you right-click on the device, choose Properties. Check the General section to see if the computer thinks it is working. Look the events tab for details like a "Further Installation needed" message.
I hope this helps.
(Note: some USB ports do not hold the cable properly. If the cable is wobbling in the port, you might hear the Hardware found beep several times as the connection appears and disappears with the machine. Under some circumstances, the port can be damaged by high voltage demands (charging with a bad cable or too many devices on a USB hub) or a surge coming through the computer. You can sometimes check this by connecting a USB device that works on another port or machine to the port that may be faulty.)
The reason it said connect the original charger, could be there was a wire defect in the USB cable. It has 4 wires, 2 to charge 2 for data. It noticed you did connect something to the USB port, but could not charge. Perhaps your cable is defect, to even the charger can be defect.
Try another if possible Garmin charger and or another USB cable.
If you are using Windows you will get a chime sound when you plug & unplug a usb cable. I would try using a different USB port on the laptop and see what happens. Did the dog/cat/hamster chew on the cable maybe? I would also try another USB A-B cable.
My GPS is crony, i do not have an updated maps. what is the option to update for GCC countries and other asian countries. please advice. presently i am in saudi arabia. also i travel all GCC
Cannot Communicate; install USB; Install cable; installation USB; Installation cable; Cannot continue installation; Unable to press Continue; Unavailable Continue button; Continue button not active; Opaque Continue button; Gray Continue button; Continue button grayed out; USB connection not recognized Solution What you will see The Continue button is gray (i.e. Continue), preventing further driver stallation. connect the Installation Cable; using the supplied installation cable, connect to any USB port on this computer. Back Quit Continue There are several possible reasons for an inactive Continue button. Try the following suggestions in the order provided to resolve this issue: Action 1 Make sure the printer is turned on: 2 Confirm a solid connection of the USB installation cable on both printer and computer. HINT: The USB port is identified by this symbol: 3 Keeping Step 2 in mind, disconnect the USB cable from both printer and computer and then reconnect the USB cable at both ends. HINT: Listen for audio alerts or notification icons or balloons in the Windows notification area. For example, or or . 4 If your computer has multiple USB ports, try connecting the USB installation cable to a different USB port. NOTE: Passive or self-powered USB hubs may cause a problem. 5 If one is available, try connecting another USB device to the same USB port to see if it is recognized by the operating system. 6 If one is available, try a different USB cable that is under 10 feet. NOTE: Some port replicators or docking stations for laptops or notebooks may cause a problem. 7 Confirm that you are installing the correct software driver for your printer model. For example, a 7600 Series driver works with the X7650 and X7675 All-In-One. 8 Turn off the printer, and disconnect and reinsert the power supply and power cord. Click here for image. 9 Click Quit to exit the installation. Remove the CD from the CD or DVD drive. Then reinsert the CD and try to perform the installation again. To save time you can skip or close the hardware setup wizard if you have already completed these tasks. 10 Confirm that Device Manager recognizes the device. To open Windows Device Manager: Click on Start and then Run.In the Run dialog, type devmgmt.msc. Click OK.11 Next, disconnect the USB cable from the printer and reconnect it. Watch the Device Manager indow while you do so. The appearance of the items in the screen should change as Device Manager tries to recognize the device. Click here for image.Macintosh users: System Profiler is the Device Manager equivalent. Click here for instructions on accessing System Profiler, and look under Hardware > USB for the printer.12 Does Device Manager show a change in appearance?-If Yes, contact Lexmark Technical Support for additional assistance. -If No, there may be a problem with your computer and its USB support. The computer must recognize the USB cable in order for installation to work. 13 Reboot your PC and try these steps again.
io error means that the "Input/Output" is not working. This could be due of different reasons. Try the following:
1. try it on another computer if it works, it's something with your computer. Could be hardware (e.g. loose connected cable or driver)
2. try another USB cable, if it works, its due of the USB cable (or the cable has loose contact)
you connect via a usb cable or bluetooth which is a wireless connection. if you have tried connecting with a usb cable, what happens? If the device cannot be seen or recognized by your pc the most common reason is that you dont see a device you plugged in is that you dont have the proper drivers installed on your pc. See what error meesages you get, and troubleshoot! Are you saying your internet connection on your PC is via vodafone usb dongle? This should not affect your ability to connect a mobile phone via a usb cable which should work without being connected to the internet. Its all a question of hsving the correct drivers, but some software wont work with the dongle software, which has to be uninstalled. Troubleshoot for the correct drivers them get technical help from micromax
