Question about Maytag MFD2560HES Bottom Freezer French Door Refrigerator
Right Hand door swings open too fast
If I have the right hand door beyonf the "half-way" point it will open all of the way with a "crash" The left hand door seems to be "dampered" in some way. The level side-to-side and front-to-back seem ok.
  • 35 Answers
Re: Right Hand door swings open too fast
On the bottom of the door there is a part called a door closure kit.It operates like a cam. There are high and low points on the part that aid in the opening and closing of the doors. Do-it yourselfer project.
Posted on Dec 09, 2007
0 characters
3 Points
The refrigerator right side door swings all the way around when you open it (180 degrees). Shouldn't it stop half way? How can this be corrected?
Your frig should be properly leveled left to right and front to back when it was installed. If it is done correctly, when you open the door it should stop where-ever you stop it and it should stay there until you close it. If it swings either closed or open when you let go of the handle, it's not level. The door stop is there to keep the door from opening too far.
Jan 04, 2015 | Refrigerators
Fridge door doesn't stay open
make sure frige is level left to right. then make back slightly lower than front. while making sure it is level left to right.
Apr 19, 2012 | Refrigerators
How do I change the door from left hand to right hand opening
on the top right hand side of the refrigerator you should see little screw cover caps,, also on the door and on the bottom of the door. remove these caps -- now remove the screws that hold the hinges for the door and just switch everything over to the other side. everything is a mirror image of the other side --- where there is a screw that holds the hinge on one side -- there will be a screw hole on the other side that is covered by a finish cap,,, same thing with the hinge pin hole. tighten everything up and use the finish caps to plug up the now exposed holes and there you go -- right hand opening door.
if you have any troubles -- just write me back here and I will do my best to walk you through it.
Feb 03, 2011 | Kenmore 72912 / 72914 / 72919 Bottom...
Door swings open too fast
Good day,
First check to see if the machine is leveled.
Make sure it is if anything not tilted forward. Very slight to the rear is ok.
As well ( if we are talking about the fresh food door), make sure the machine is not tilted to the right.
If the leveling is ok, then check the bottom hinge on the door to see if the cam which aids in helping the door close on it's own is not broke. If that is the area where the problem is, with a complete model number from the machine in hand, go to any appliance parts house that carries GE parts.
They should show you a exploded view of the components and what components you need.
Nov 03, 2009 | GE 25.4 Cu. Ft. Side-by-Side Refrigerator...
Help . Change doors from right to left opening
first remove the door from the fridge, remove the hardware connected to the fridge, on the opposite side should be rubber or plastic caps covering some bolt holes. remove caps and install top of hinge transfer everything you see on the left to the right
Oct 21, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
How to reverse door on kelvinator fridge?
Im unable to look up htat particular model number for you, looks like my FRT18, which is made by the electrolux company, in which case, YES you can easily switch the door swing form one side to the ohter, whats on the left goes to teh righ and right to the left, not a problem
Jan 11, 2009 | Refrigerators
Can the doors of both the refrigerator and freezer be reversed to open from the other side?
yes take off handles remove center hinge between doors then top and bottom now put all on other side replace doors and handles Thank you
Jun 25, 2008 | Kenmore 64702 Top Freezer Refrigerator
Maytag Fridge French Door hinge discrepancy - hard swing
Vhotho, Maytag put out a service bullitin regarding this problem. This of course is for the model that is posted. The fix is to install a new right side center hinge and door stop limiting the opening to 135 degrees. They must of redesigned it. I can give you the part numbers. Black and stainless the hinge is 67006443 and the stop is 67006276. For white the hinge is 67006379 and the stop is 67006278. This bullitin came out in Feb of 2006. TDR-0057a-b. back.
Jan 04, 2007 | Maytag MFD2561HE Bottom Freezer French...
Maytag MFD2560HES Bottom Freezer French Door Refrigerator Logo
203 people viewed this question
Top Maytag Refrigerators Experts
Richard Roth
Richard Roth
Michael Thomas
Michael Thomas
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
