Question about GE 31GT660 TV
The TV is only showing half of the picture - GE 31GT660 TV
  • 3 more comments
  • Anonymous Dec 11, 2007
    I have a sony flat screen 68cm tube trinitron tv and the top half half is black and there is a line through the middle and showing picture on the bottom. Is this a major problem and worth getting fixed?
  • jodie watkins Dec 11, 2007
    I have a sony 68cm flat screen tube trinitron tv. On the top half of the screen it is black then a line through the middle of the screen and there is picture on the bottom half. What is the problem and is it worth fixing?
  • Anonymous Feb 23, 2008
    I have a sony 32" Trinitron and it is showing only half of the picture. Top half is black with a bright white line going through it. The bottom half is showing half the show that is on. This is happening on all channels and while viewing DVDs.. Should I be going out to buy a new tv?
  • agentlily1 Nov 14, 2008
    I have a Sony TV that I bought last year. Last night it started showing only the bottom half of the picture seperating the top part by a bright line. The top is black. It is the same on all channels. Is this a serious problem?
  • jackuar Dec 09, 2008
    mine is an old 14inches B/W (onida)tv only half screen is visible other part appears black
  • 31 Answers
Hi Bigtate,
There is not much for me to go on with your description but here goes,
I suppose you have a convential TV set with a glass picture tube and not one of the new types with the large screen slim style displays!!!
If it a glass type picture tube then the following assumptions are made.
I hope yopu have not shifted house recently and moved the TV around???
If you have its possible the Yoke (its a device on the neck of the Picture tube that controls magnetically the scanning dot) may have moved and only is letting you see half a picture...
This is a long shot but it could be the cause..
Now the picture is supplied to you by a fast moving dot of light (Black & White set) that scans from the top of the picture and moves very fast down to the bottom of the screen, then flys back to the top of the screen and starts all over again during this process the dot lights up the picture tube to provide you with
the picture you see... (On a colour set there are three dots)
Its quite a complex process and its all controlled by electronics inside the TV receiver.
If you are getting only half a picture then something is causing the dot to only turn on for the lower half of the picture during its write time to the glass screen,
You dont say if the half thats off is white or black, so there are many things that the service technician needs to know before even starting to look for this fault. During the dot doing its write cycle down the sceen, when it reachs the bottom and flys back to the top of the screen it receives a synchronous pulse from the TV station, and this TV signal is critical in making sure you see the same picture as is being sent from the TV station.
Sometimes this sync pulse from the TV station is very weak and so your picture may float up and down the screen trying to lock to the incoming signal.. this just may be your fault.. but you dont say if the half of the picture that you see is floating or not..
Your situation may be that your TV has partially locked to the station signal and your aerial may be problematic,
but then you dont say if its on just the one channel or all of your station channels. So there needs to be more analysis of your situation prior to a positive answer being provided....
Sorry I can be of more help...
From YUBEUT...
Posted on Nov 10, 2007
Pick it up and slam it on the ground it worked for me
Posted on Nov 27, 2007
Only half rca tv screen shows up
I think you may have a tv tube problem...
Jan 26, 2014 | Televison & Video
my TV has a half black & half white screen & half of the TV is showing the picture including the normal sound,what can I Do,?
Dec 11, 2013 | Panasonic Viera TH-42PZ80U Plasma TV
47" Vizio LCD Smart TV, left half of picture is black & other half works fine. Sound works fine.
when i start tv 1minit picture show 1minit after no picture but sound have
Nov 18, 2013 | Televison & Video
Only TOP half of picture shows, rest is black???
No,problems u discribing the LCD screen panel some how it shorted and dead.Replacing the LCD screen panel is not an option,because LCD screen panel are 90% of the tv,so replacing it.LCD screen panel will cost the same as a new tv,because LCD screen panel are limited produced by the tv corporations.It time to buy a new tv.
Jul 31, 2010 | Toshiba 32AV502R LCD TV
Half screen showing picture other half showing color lines
This is a catastrophic and known failure of older Toshiba sets, not much you can do, try to take out a retrospective extended warranty, wait a month and claim, good luck.
Apr 19, 2010 | Toshiba REGZA 52RV530U LCD TV
TV shows on half screen. other half fuzzy
You have some cold solder joints on the PC board. Flux and re-flow all of the electrolytic capacitors connections..
Aug 29, 2009 | Televison & Video
Half screen showing
keep tv off.
it will only get wors
if sumon dosent work on it soon
the problem you are having in the vertical section of the tv
hav a repairman resolider all conection on the vertical IC and check the serounding componets for falts.
regards daniel.
PS the repair takes me about 15 min.
Jan 13, 2009 | Samsung TXG2746 27" TV
42" LCD tv shows picture on only half of the screen,other half dark!
The T-Con board (otherwise known as LVDS) connects to two seperste parts of the LCD panel. If you do have half a picture (left or right) replacing the T-Con board should resolve this issue. Open your TV, find the part number and search on eBay or at sites like where you can search by TV model number.
Oct 27, 2008 | RCA L26WD26D 26 in. LCD TV
My LG 37LC55 LCD TV has one half of the screen darker than the other
Is the XD Demo on. This shows half of the screen with the XD picture engine on and the other with it off. Check your picture settings in the menu.
Good Luck
Jan 05, 2008 | Televison & Video
GE 31GT660 TV Logo
2,447 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
