Question about Panasonic CT-36HL43 36" TV
No Power on Panasonic 36HX42
Fell asleep in front of the TV last night, when I woke up TV was off -- thought that was odd but went to bed. Today, no power. Can't turn on from remote or power switch on front. Was plugged into a Monster power surge strip (all other electronics plugged into this strip are working fine). If I unplug the power cord, then plug it into another outlet on the strip (can't reach a wall outlet), then press the power button, a red light comes on for about 2 seconds, I hear one beep, then no power again. The TV was purchased new in March 2003. The TV is too large to see the back or get to the back (it's in a large TV cabinet). I cannot move the TV by myself and do not have anyone to help. Panasonic web site says I don't have the right model number even though 36HX42 is what is printed on the owner's manual and I matched the photo on the Panasonic web site. Is there a reset button? Possible problems? Panasonic web site says to carry it in to an authorized repair shop, problem is I couldn't possibly carry it anywhere! and the closest shop it 43 miles away. Can you help?
  • 1879 Answers
SOURCE: No Power on Panasonic 36HX42
The TV cannot sustain power - well the good news is, it is on the POWER SUPPLY section inside the TV
Posted on Jun 18, 2008
0 characters
1 Points
I have a 1996 Panasonic tv #CT 20621U. Great
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Oct 14, 2014 | Standard (CRT) Televisions
My sony trinitron is blinking red and won't turn on
Jun 25, 2013 | Sony FD Trinitron WEGA KV-34HS510 34" TV
Model CT-36HX42 - power to set, no power, no picture, no sound. Is there a fuse or reset?
The main power regulator section has to be troubleshooted. It is a skilled work and not a user repairable one.
Aug 26, 2012 | Panasonic CT-36HX42 36" TV
The on light is blinking but there is no picture or sound.
I have the same problem with my JVC AV27750, the problem is probably the power supply relay circuit, just check and replace the 1000uf capacitor
Jul 06, 2009 | JVC AV-36260 TV
Suddenly SNOW on all channels
your tuner has failed;
time for another set the cost to repair is too high
May 29, 2009 | Standard (CRT) Televisions
Sanyo 31'' Standard Def CRT TV
This is a vertical problem that can be as simple as poor connections at the vertical IC or a defective IC. If you can solder, you should be able to fix this yourself. Realize that there are potentially dangerous high voltages present inside hte set even when unplugged. If you wish to attempt this repair, please update this and confirm your model number as DS31590 and I'll supply additional details and instructions.
Feb 24, 2009 | Sanyo DS31590 31" TV
Jun 18, 2008 | Panasonic CT-36HL43 36" TV
Panasonic CT-36HL43 36" TV Logo
396 people viewed this question
Top Panasonic Standard (CRT) Televisions Experts
Jaime Hernandez
matt martin
matt martin
Are you a Panasonic Standard (CRT) Television Expert? Answer questions, earn points and help others
