If there is a source selector button [TV/Video]; at the front panel controls at the TV; you should have a remote control to select the input source to TV. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops.
SOURCE: Re: Can't change from Video
You will need the remote to do this. If you can't find the remote get a universal remote with a video or input button on it. The other set may not be the same model and has different features.
SOURCE: change channel without remote
Hi , there is a button on your tv set near the channel button. that will set your tv to video.
SOURCE: Describe your sanyo moddel number DS27590Problem,
Hi there
Check the set to see if it has a source or A/V button. If not, the only thing that you can try is to scroll with the channel buttons up down buttons to see if you can get to the TV channels.
It is likely that you have already tred that:) If that has failed you, then you WILL need to remote to do this. I am sorry to say that this is the only way to get there. You can purchase a remote online from here
Not the only solution you have, in light of the impending change from analogue to digital... you could put your money towards a digital set top box and solve the remote issue at the same time. Check out what you can get from here. They start at less than $50, and could plug into the set you have eliminating the need to change it out of AV mode. You also get extra channels :)
Happy to answer any questions that you may have about it. Cheers
regards
robotek
