SOURCE: wiring a midland 78/999 cb radio microphone
Pin 1 = white
Pin 2 = shield
Pin 3 = black
Pin 4 = red
SOURCE: converting a different brand of mic for a midland CB
This should be a typical Midland pinout. If you are using a generic 4 pin mic that is wired to cobra/Uniden, all you have to do is switch pin 1 & 2, then 3 & 4.
Not all mics are color coded the same with their wires.
SOURCE: On my 77-099 Cb MIDLAND Radio I wonder can i use a
Buy a magnetic mount CB antenna ($35.00 for a K30 magnet mount cb antenna) and put it on the fridge, or microwave, or a appliance thats heavy in metal (gives good ground) and it'll work fine. A base antenna will be even better though. www.copper.com for antenna's and radios
SOURCE: Midland alan 42 multi CB Radio
The user manual can be found in PDF form here: http://www.alan-uk.com/cb/manuals/42%20multi%20manual.pdf
SOURCE: lookin for info on midland cb 13-830 and 77-824
Both radios are AM only, the 13-830 is 23 channel and the 77-824 is 40 channels. Of the two the older 23 channels is a better radio and is able of more frequencies.
