Have haier HWRO5XCM air conditioner. Outside temp is 75 degrees and I have set on 76. Freezes up and spits ices and water. Help
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 69 Answers
Clean indoor filter , and coils in unit (you must remove from window and remove top from unit to expose coil, After cleaning coils prop up unit so it slopes to rear and spray back and forth at bottom of front coil until drain is clear . Never turn unit upside down , and do not get water inside of fan motor . Also clean evaporator blower wheel . With unit clean and drained out place in direct sunlight for at least 2 hours to completely dry before replacing top and reinstalling in window , or just drain out , reinstall and leave unit unplugged for at least 24 hours to dry before testing . If unit is clean and still icing , check to see if thermostat works (place object in front of unit to direct cold air from top of unit onto thermostat temperature sensor and compressor should cycle off, if not replace thermostat . If unit still ices you will need a pro to repair sealed system of unit or simply buy a new one .
Thanks,
Alex
Posted on Oct 05, 2014
SOURCE:
chillmaster
  • 104 Answers
SOURCE: samsung 8000 btu window air conditioner
Air conditioners rely on a difference in pressure between the "high side" and "low side" in order to perform. Of course, a/c's are designed to work in the heat. Having a cooler outdoor temp of 70 degrees probably is not sufficient to maintain adequate head pressure and will result in reduced cooling capacity. Also, since it was 68 in the morning in the room, it is possible that the indoor coil began to freeze up. Basically, you have a cold coil that you keep warm by moving air over it. If the air doesn't have enough specific heat (what your thermometer measures) it can allow the coil to get colder than 32 degrees and the condensate from all of your humidity will begin to freeze on the coil. My recommendation would be to check the a/c on a day that is 80+ degrees. If you have an avarage indoor temp of 70 degrees you should be able to look for the air coming out to be approximately 20-25 degrees colder than the air being sucked in.
Posted on Jun 12, 2008
  • 6 Answers
SOURCE: WINDOW AIR CONDITIONER SHUT ITSELF OFF
Some units have a dehumidify setting to overcome this as they go through a defrost. You can either manually defrost running on heating for a few minutes, or have it defrost when it goes out on fault as happened.
Posted on Jun 20, 2009
daddyo742001
  • 70 Answers
SOURCE: I have a GE air conditioner with ditigal panel. I
Wash out outside coil from time to time.This is the most over looked part of window units. Take care not to spray water directly into fan motor. If not real humid in house check temp coming out of ac inside and make sure filter and coil are clean. run on high speed and the air should have good force. 20 to 30 degree temp drop of room temp should be about right. Much depend on outside temp and humidity and indoor humidity plus insulation factor of area. How many people are in the area and if you keep unit on day and night .
Posted on Jun 28, 2009
SOURCE: Air conditioner constantly running, not cooling house
Ours was worse than yours. It was not frozen up, but it did need freon. The tech told us that the compressor coil (the unit in the attic) was leaking freon and that the unit would have to be replaced within a year, but adding freon dropped the temperature inside from the mid-80s to the mid-70s (on 100 degree days). It might go lower, but we don't set the thermostats below 76. We paid $80 for the service call plus another $197 for 3 lbs of freon (for our 4-ton unit). Total cost: $274. The quote to replace the system with a new 14 SEER unit is $7,000 -- but this will get us through the summer. Oh, be sure to replace your filters monthly and keep your condensor fins clean. Spray them down with a hose (even while the unit is running), make sure there are no leaves or other trash blocking them, and make sure you have 2 feet of clearance around the condensor. Putting plants or other objects right up against it will impede its operation. Good luck!
Posted on Jul 04, 2009
t1m130
  • 86 Answers
SOURCE: Carrier Air Conditioner- not reaching set temperature
if it is set to 76 degrees and its 78 in the house its working fine it is suppose to shut off once it reaches 76 but sometimes there is a 1 or 2 degree differential built ini would keep you filter clean and as long as it blows out cold air i wouldnt be to concerned most airconditioners need yearly cleanings though
Posted on Jul 14, 2009
My air conditioner wont go below 70 and i need to know how to do it, i want it without the manual so I have no idea? PLEASE help me
It is likely you will not get it to go lower. Rule of thumb, a good AC will chill the air UP TO 20 degrees below whe prevailing outside temp ... down to about 70 ... maybe a little more. So it if it 90 outside, you should get 70. If it is 100 and you are getting 72, you are doing good.
Haier is a good name and my free advice is be careful that you dont damage your machine by demanding it go beyond usual parameters. Have you reviewed the owners manual?
I should also mention the lower you set the temp ... the higher your power bill will be as a result.
Thank you for your interest in FixYa.com
Aug 26, 2011 | Haier HWR08XC7 Air Conditioner
Haier 5500 window unit, spits water into the room sometimes. Also, water "sloshes" around inside the fan area & is quite noisy sometimes. ? Thankyou for your assistance...
You will need to reposition the unit to where it will be tilted downwards slightly outside.
The water will then flow out the back and not spit into the room.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 16, 2011 | Haier hwr10xc6 Air Conditioner
Window air conditioner is spitting water
Hello, usually a window AC will spit water if the unit is not tilted back or if the drain is backed up, if the unit is level try tilting it back it the window somewhat. Also, if the unit does have a drain make sure it is not blocked.
Jun 19, 2011 | Haier Hwr10xc6t Air Conditioner
Unit will not cool below 76 degrees
Sounds like you need a freon charge on the unit. Check filtes for air restriction as well.
Jun 23, 2010 | Haier 539490003 Air Conditioner
My termostat is set on 71 but the temp inside says 76 while it is 100 outside is that normal?
rule of thumb is that an a\c unit will keep a house 20 degrees cooler than outside air temp
Jun 19, 2010 | Heating & Cooling
Jul 14, 2009 | Carrier 38CKC036 Air Conditioner
Check and see if it is froze up. Check big line at outside unit for ice. check filter and replace as needed. Check outside fan to see if it is running. Wash out outside coil If fan and compressor are running and has hot small line at outside unit. If not froze up and coil is clean you will need to call in a pro. If compress over heated you may need to wait for it to restart if coil was dirty. Again make sure out door fan and or unit is running and clean.
Jun 29, 2009 | Goodman CKL49AR49 Air Conditioner
Jun 19, 2009 | Heating & Cooling
I just bought a samsung 15k BTU window a/c, I haven't seen any water dripping out of the bottom of the unit. In fact there is absolutely no moisture anywhere. Is this normal. Humidity is low, and it is...
If the humidity is low then the amount of water removed will be low. The AC (I assume is a window unit) May be evaporating it off as soon as its drained outside..
Yes in low temps and humidity it is normal for no moisture to be made in abundance.
This is all assuming the temp is coming down as you direct it to.
Please rate me as high as you can and thank you for using fix ya.
Apr 28, 2009 | Kenmore 75050 Wall/Window Air Conditioner
Dehum
Dehum is short for dehumidify. This setting is to remove the humidity from the air without doing any real airconditioning. Also, if the a/c is spitting water out the front, then the a/c is leaning forward too far. The a/c should be at least level or maybe leaning toward the outside a little bit to help facilitate drainage.
Jun 25, 2008 | Haier hwr10xc6 Air Conditioner
Heating & Cooling Logo
61 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
