Question about GE Profile JTP56 Electric Double Oven
GE Jsp28c oj1bg oven
Bottom elament burned out, I replaced it but the red light dosn't come on any more and it heats slowly and not very hot. Broiler light goes on and heats up
5 Suggested Answers
SOURCE: GE JGBP90MEB oven not lighting. Broiler working
Igniter needed to be replaced. GE fixed it the same day.
Posted on Sep 19, 2009
SOURCE: My GE double oven JKP26GP broiler burned out
I'm afraid I don't know how to help you get a new control panel (part #WB36K5065 is no longer available). But we have the same oven and a similar problem. Our control panel works just fine, but the face is melted from a recent mishap (small fire in the upper oven while broiling), so the plastic face of the control panel looks awful and needs replacing. If you decide to replace your oven and would like to sell the front face to your control panel we'd love to purchase from you.
Posted on Dec 05, 2009
SOURCE: GE True Temp Oven not heating. Broiler works
we bought a new oven
Posted on Dec 15, 2009
  • 43501 Answers
SOURCE: Oven/ broiler will not heat and bottom element slow to reach temp
Check out this tip that I wrote about this problem...
Posted on Apr 28, 2010
  • 2118 Answers
SOURCE: I have a GE Gave
you have a bad ignitor,take out the racks and remove the floor of the oven,you'll see the round ignitor with two 1/4 inch screws holding it on,you can remove the burner tube that the ignitor is connected to with the ignitor on it or you can remove the screws,cut the wires close to the old ignitor and remove it,screw on the new ignitor,leave around6 or 8 inches of wire on the new ignitor,cut back the old wires so you can wire nut the wires together,start the oven and the ignitor should ignite the flame in like 20 to 40 doesn't matter what wires you connect,you don't have to worry about if the left wire coming out of the ignitor connects to the same wire the old one connected to,just as long as the wire nuts are tight on the 2 connecting wires you'll be fine.the part number is WB13K21 and the ignitor is around 80 can kill the power to the oven but no power is going to the ignitor if the bake isn't on so as long as you don't touch anything else you'll be fine,let me know how you make out
Posted on Nov 15, 2010
0 characters
1 Points
Broiler will not come on when baking
Take a look at the element ( the "tube" inside the oven that glows red hot when the oven is turned on). If the element is burned out it will not be hot and glowing. You may have a loose connection to the element but most likely it is burned out and needs replacing.
Our stove is 27 years old and I have had to replace top or bottom elements every 6 years or so. I just bought a replacement element at Canadian Tire in Calgary for about $34. Just undo the 2 screws around the element and attach the new element to the old wires.
Good Luck -I hope this works for you
Jan 10, 2013 | Moffat Ovens
Lower element not getting hot enough. Broiler works.
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
Mar 20, 2011 | GE Ovens
We have a GE gas oven/stove top and the stove top is lighting as well as the broiler but we can not get the oven to heat up. What do you suggest we try?
i just moved and our stove in the new place doesnt bake things right. it seems that the top coil doesnt come on. its very difficult to bake anything. seems to come up to temp for pre heating, but only the bottom coil comes on. If you put it on broil, then the top coil gets hot. that works fine. tired of burning pizzas and biscuits. can anyone help with a cheap fix? dont have alot of cash.
Nov 12, 2009 | GE Ovens
I have a GE Profile Spectra XL44. When I turned my oven on to 375 it read 100 degrees for 10 mins. I open the door and there was no heat. I then tried the broiler to make sure it worked and the the element...
i wouldn't say it is "normal", but yes, the bake element in the bottom could have burned out again. it depends too on how often you use the oven. if you use it every day, chances are it will burn out quicker than say someone who only uses it once a week. you can check the element for a burn hole or a blister break. you can also check it for continuity with an ohm meter if you have one. hope this helps.
Nov 07, 2009 | GE Ovens
Sep 18, 2009 | GE Ovens
I have a GE Single Wall electric oven.(JTP25SOH2) The heating elements just stop getting hot. unit is about 4 years old purchased brand new. first the broiler stop getting hot then the baking heating...
First your broiler heating element may have gone bad and now you oven heating element may have gone bad. Using an OHM meter disconnect them and test for their value.Full scale on the meter means it is shorted. No meter movement means that it is open.Eitehr means to obtain a new element(s) and replace it/them.
Jun 11, 2009 | Ovens
The oven broiler work but the baking part doesent.
hi thanks for the question I would replace the bottom igniter it has failed thanks the appliance doc
Sep 30, 2008 | GE JGRP17 Gas Single Oven
Most modern gas ovens and many broilers use a "glow-bar" style of igniter that glows red-hot to ignite the gas. If the igniter doesn't reach the proper temperature, the gas valve won't open. You may need to replace the igniter.
Oct 30, 2007 | Frigidaire FEB27S5A Electric Single Oven
GE Profile JTP56 Electric Double Oven Logo
Top GE Ovens Experts
William Miller
William Miller
Michael Thomas
Michael Thomas
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
