SOURCE: I have a Delta Series
hi roger,
Sorry Delta 1300 and 1400 series valves do not have a volume control. Kinda odd but that is how they are made.
Please rate this response and Good Luck, Phil
SOURCE: I installed Delta shower faucet 132900 and I could
Did you solder the valve in? If so you may have got it to hot. Or debris could have gotten in the valve. Turn the water off, remove the handle and cartridge. Check cartridge for damage or debris
SOURCE: replace delta single handle shower cylinder
Yes, I believe this unit uses a cartridge right? They do fit a little tight due to the small washers on the back side of the cartridge. If this is the one I'm thinking of, there are two leg like appendenges that come off the back and fit into small holes at the back of the manifold or what some call mixing valve housing.
SOURCE: repairing a delta single shower faucet. The handle
There is a nut that needs to be removed, allowing you to remove the ball assembly.
Look at the ring nut right below the #1 in this pic.
Your's should be similar to this one.
SOURCE: Need to fix a leaking delta shower faucet and need
find the set screw on the handle loosen and remove handle, remove locking ring (a tool to do this comes with the replacement kit that you can buy from hardware store) remove the ball. You now have access to the washers and springs remove old washers and springs install new. reassemble in reverse. make sure not to overtighten locking ring.
