Bosch Washer And Dryer Stacking Kit WTZ11310 Logo
A
Anonymous Posted on Oct 03, 2014
<!-- from fixya rte -->Bosch stacking kit installation manual - Bosch Washer And Dryer Stacking Kit WTZ11310
MAX POWER
Level 2:
Sergeant:
  • Expert 419 Answers
  • Posted on Feb 03, 2015
 MAX POWER
Expert
Level 2:
Sergeant:
Answers
419
Questions
0
Helped
113297
Points
758
Go to manufacture web site and download need documents
How do I detach my Bosch drier from yhe stacking kit as I need to replace the drier
most model have some bolts or screws to keep dryer safe on top of washer
just remove bolts and screws and pull back the dryer
1helpful
How do you unstack a Bosch Axxis WTA dryer from a Bosch Axxis WFL 2050 washer?
You do not state the type of stacking kit installed on your Bosch washer. The installation instructions of one of the stacking kits is found at the site Assemby Instructions Bosch Axxis Stacking Kit /WTZ11310.pdf . First remove the front concealment strip to expose the front of the mounting kit. Gently pry with a wooden tool to prevent damage. Once the it is exposed, there are two clip inserts in front of the dryer feet that must be removed. Once these are removed, you pull or slide the dryer forward to release them from the stacking kit and simply lift the dryer off of the stacking kit and the washer. The stacking kit itself is attached to the washing machine with four screws that must be removed to separate the kit from the washer top. And with that, your dryer and washer are separated!
But after separation there are two additional problems that may be bothersome to you. The first is that you now have mounting holes in the top of the washer that are exposed and the second is that the feet on your dryer may need to be replaced as parts of the feet may have been tossed during installation of the stacking kit and may need to be replaced.
The assembly instructions above show only the basic stacking kit. Some kits included a slide that pulls out to allow for a handy tray but the installation or disassembly is nearly the same.
I need installation instructions for the Bosch Clothes dryer stacking kit.
Just go online and check out support line on manufactures website for instruction
1helpful
Remove stacking kit from Bosch tumble dryer
I have got the same problem - did you manage to fix it?
How to un-stack Bosh Washer WFL 2060/Dryer WTL 5410
Did you ever get an answer? I have the same problem...
Stacking Frigidaire dryer on washer using stacking kit 5303937141
i have the two brackets but have no idea how they attach. does the top come off the washer?
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
