While driving my impala the check engine light came on drove it 9 more miles to get to a store it stalled, then hard to start, sounds like it is missing got it home barely, now it really hard to start still missing and it is flooding itself can any one help
SOURCE: loosing power
Wow, I just went through the same problem and guess what it was a clogged converter and a bad oxyegen sensor. The garaged fixed it up for me by putting an eco converter on it and a new O2 sensor. I have a 2003 Chevy Impala,V6 3.8 engine. Good Luck!!!!
SOURCE: 1989 corvette: battery losing voltage, hard to start and stalls
I dont know much about corvettes But if the voltage regulator is in the altenator it could be sticking drawing voltage even if the car is not running. Dis connect the plug in overnight and see if it starts in the morning if it does the regulator is sticking shut replace the alternator
Was this helpful or did it solve your problem please rate
SOURCE: Transmission Shakes Check Engine light is on
fit a manual gearbox ??check oil level with reverse gear selected ,engine running and chocks under drive wheels .
SOURCE: Chevy Impala can't shift out of park
sometimes this happens if the brake light switch is broken - the car thinks that you do not have your foot on the brake, so will not shift out of park . strange however about the ABS light being on. i would get a garage to get the fault codes read
