The pump has broken and I can't get the clothes out - they are sat in the soapy water, how do I over ride the locking mechanism?
You need to get the water out before the door will open. One way is to lower the drain hose into a bowl / bucket to allow the water to run out. Another way is to tilt the machine back, place a bowl under the filter and loosen off the filter so the water gradully flows out enough to open the door. Once all the water is gone you may find a coin or something jamming the pump.
SOURCE: hotpoint aquarius washer door wont open
I've got the same problem, the locked symbol is showing
SOURCE: Fixing broken door lock of Indesit W123X washing Machine
no easy way to open
disconnect from mains
take top off. feel down the front to where the door lock is and see if you can feel the door peg sticking thro the door interlock. force this with your fingers and with luck the door will open
if can't do this way, break handle off and lever peg with a small screwdriver
you can buy a handle kit complete. fitting this is not difficult - split the door and all will be revealed advise you make a carefull note of where springs go etc before you start stripping it down or take a few fotos if you have a digicam
SOURCE: Broken door handle Hotpoint WD860
Managed to work it out, you have to slide the outer door case away from the handle locking mechanism, slide left and move away (after undoing the 6 screws on the inside) :-)
SOURCE: Kenmore Elite HE4t Washer Control lock lit, door locked
121 MINUTES USUALLY DRAIN CYCLE PLZ REMOVE 3 BOTTOM PANEL SCREWS 7 MM SCREWS, TO OPEN DOOR SLIDE RIGHT HAND TOWARDS DOOR LOCK ,THERE WILL BE A SMALL LEVER TOO PULL DOWN ,NOW ITS OPEN,,, SINCE U HAVE BOTTOM PANEL OFF PUMP IS RIGHT IN FRONT REMOVE PLASTIC HOUSING CLOCKWISE ,,,REMEMEBER HOLD 3 GALLONS OF WATER STILL ,HAVE BUCKET READY ,NOW CLEAN OUT PUMP AND DEBRIS ,, CLOSE IT UP SHOULD BE FINE NO MORE PROBLEMS ,,,,,
SOURCE: Bosch Nexxt Essence Washer
i have the same problem with a bosch at a rental unit i just moved into. the door is locked up until the 25 or 41 minute cycle depending on the cycle used.
$500 to fix the motor, YIKES! and its my responsibility, yikes again.
definitely a motor problem not a door problem.
