Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
Shampooer tank not working
I have a bissell 9500 proheat shapooer and have cleaned my carpets twice and shampooed my sofa and the shampoo tank does nt look like it is releasing any shamoo, it is at the same level that it was
  • Mike834 Feb 01, 2008
    I have the same problem, if I spray solution manually the unit picks it up just fine but it will not disperse on it's own. I opened a panel on the bottom and noticed an impeller so I'm not sure if the drive to this is broken or what. Just a note, the first unit I bought (at Walmart) had the oppposite problem, it had output, great output but then it would not pick up the solution. I brought it back and exchanged it and it worked fine for several months. If there is a schematic for this unit I would attempt repairs myself.
    President:
  • 1,673 Answers
Most times there is a problem with the cap and insert at the bottom of the tank, part #2036675. Either that or the tank isn't sitting flush and down all of the way, leaving a gap. If this is less then 1 year, then it is under warranty.
Posted on Feb 06, 2008
WE HAVE A 8920 AND WILL SPRAY SOLUTION WITH THE HAND TOOL, IT WON'T SPRAY THROUGH THE BOTTOM TO THE CARPET
Posted on Jun 27, 2008
My Bissell proheat carpet cleaner (this is my second one because the first one stopped working as well) won't dispense water, cleaner, or suck anything up. The motor turns on but that's about it. It is...
I'm not a big fan of Bissell products to begin with, but I can tell you from many, many years of experience that, far and away, the most common cause of problems with any of the carpet shampooer, steam cleaners, etc., is that they are stored with unused materials in the tanks and hoses. They are seldom cleaned, rinsed, or receive any type of cleaning before being put in the closet to be pulled out sometime in the future, with the very next attempt at application of the shampoo, or cleaner or whatever is still in the tank, not happening, because the hoses are plugged with a gelatin like substance. This is, in reality, what happens to many of the shampoos on the market, when they are left unattended for long periods of time. You haven't mentioned your cleaning, maintenance procedures concerning the unit, so I have no way of knowing just what may be causing your product, however, I think if I were you, and not using something more than twice a year, I think I'd look into renting a cleaning unit, rather than owning one.
Oct 22, 2013 | Bissell 1699 ProHeat Clear View Upright...
I shampooed my carpet, loaded clean water twice and added the cleaning solution. Then it dawned on me, the carpet is wet and there is not dirty water return. What am I doing wrong?
Look for a place where the dirty water reservoir is not sealed. There is air being sucked in somewhere else instead of the bottom where it's supposed to **** the water.
Jul 20, 2011 | Bissell 9500 ProHeat 2X CleanShot Upright...
I have a blue bissell preheat 2x. While shampooing it will start to leak dirty water. When i'm done shampooing my carpets look even more filthy then when I began. Not sure why this is happening besides...
You should drain the dirty water, you should find where it is stock then drain it. If there's some leak, seal it with an epoxy. Thoroughly clean the inside and you will find there's a stock of old shampoo which causes water to become dirt.
I hope my advice help you.
Jul 13, 2011 | Bissell 9500 ProHeat 2X CleanShot Upright...
I Need the instructions on how to use the bissell proheat 2x shampoo carpet cleaner
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
qer
Aug 24, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell Pro heat 2x the shampoo tank empties out
the o-ring is likely dislodged on the screw on cap
personally I would recommend just filling the soap container with water and a little bit of white vinegar instead of the detergent. You won't leave soap residue in your carpet that way.
Dec 22, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Will not **** up shampoo
It sounds like a suction problem. Try checking the lint filter. It is located in the top clear plastic section (the one with the dial to switch from floor to tool use). It is a small red filter, about 1 inch square, with a little door on it. Flip open the door and you will probably find it is clogged with hair, carpet fibre, etc.. Clean it out and your suction problem will hopefully be solved.
Jun 27, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Shampoo won't **** up water on carpet
try seeing if your lint filter is clogged. you will find this in the upper section of the water tank.
Sep 17, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell PROheat 2X shampoo carpet cleaner
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618960&thid=565019
Bissell ProHeat 2X shampoo carpet cleaner
Posted by boomerboo on May 02, 2008
I don't have the instruction for this machine; if you could help me with were to put the water and cleaning solution and how much. Thank you, Sharon my email address is sharonlee326@yahoo.com
Comment by boomerboo, posted on May 02, 2008
I need direction on how to use the shampoo carpet cleaner
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Bissell 9500 ProHeat 2X Clean Shot Upright. The best place to get the owner’s manual for the Bissell is to check the Bissell website or to call the Bissell factory or manufacturer and give them the Model # of your unit and they will mail you out one. Always use genuine Bissell products made for the model that you have for best results. So check with your local factory authorized vac dealer that carries and services Bissell. I will give you the Bissell factory phone # listed below for further questions. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.bissell.com/ Customer Service 1-800-237-7691
Hours of Operation Monday thru Friday 8:00 am to 10:00 pm EST
Saturday 9:00 am to 8:00 pm EST
Mail To: Headquarters, Bissell Homecare Inc
P.O. Box 3606 Grand Rapids. MI 49501
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 02, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
How to use bissell carpet cleaner
On the 1698 modle thier is a large clean water tank and a smaller shampoo bottle which seats on the side of the machine.
the shampoo goes in the smaller bottle fo the two.
Jan 02, 2008 | Bissell 1698 PowerSteamer ProHeat Upright...
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
367 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
