Washing Machines Logo
A
Anonymous Posted on Oct 03, 2014
My kenmore washing machine series 80 model stuck in soak cycle and will not pass to rinse cycle
Tony Doyle
Level 1:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Contributor 75 Answers
  • Posted on Oct 04, 2014
Tony Doyle
Contributor
Level 1:
New Friend:
Greenhorn:
Answers
75
Questions
Helped
10591
Points
90
This is usualy caused by the cold water not entering the machine. If you hear a humming noise it means the fill valve is operating but no water is present. Has some one turned the cold water off? Failing that the fill valve may be faulty and need replacing.
5 Related Answers
TheMobilian
Dan Webster
  • 8221 Answers
  • Posted on Jan 22, 2009
SOURCE: washing machine will not rinse and empty
LID SWITCH read more HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Anonymous
  • 58 Answers
  • Posted on Jul 01, 2009
SOURCE: kenmore 80 series model 110 after wash clothes are left soaking
when empty and off, open the lid and see if you can rotate the inner wash basket by hand. if you can easily, then the clutch is worn. This will prevent the basket from going into a high spin and wringing the clothes out. Replace the clutch by removing the top control panel, removing the clips that hold the cabinet, pull cabinet off, remove drain pump clips and pump, remove motor clips and motor, remove transmission (3 bolts). Now you will have access to the clutch, replace as needed, reverse dissasembly to complete. remember to unplug.
Anonymous
  • 135 Answers
  • Posted on Sep 01, 2009
SOURCE: kenmore series 80 washing machine won't drain
Check the lid switch under the edge of the top where the lid closes. When you are about 1 inch from closing the lid you should here a little click sound. That is the switch closing. I fyou do not here the click then the switch is bad.
Anonymous
  • 401 Answers
  • Posted on Jan 02, 2010
SOURCE: Sears Kenmore series 80 washing machine stops after wash cycle
Sounds like the lid switch.
Anonymous
  • 1937 Answers
  • Posted on Jan 18, 2010
SOURCE: No Spin Cycle in Kenmore 80 Series Top Loading Washer
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer: Following is the Sears site for Whirlpool (110.) models with your model number.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.23812100
and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
Following is a description of how to release the console for access to the pins.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part.
How to just run the spin cycle?
https://www.manualslib.com/manual/85754/Kenmore-29522.html#manual
Kenmore 600 Series Pdf User Manuals. View online or download Kenmore 600 Series Use And Care Manual. ... Kenmore Washer Use and Care Guide.
Probably the worst washing machine manual I have ever read!
Try this.
Put your wollens in the machine, set for cold water, Woollens Cycle and your 'Soak' detergent. It will agitate a bit, and as soon as it stops filling, turn it off.
After say 20 minutes. Then Move the dial to Spin, and pull the knob out. It _should_ pump out and spin.
1helpful
1helpful
Rinse cycle do not disengaged
does it drain?did you check the lid switch?
Kenmore 90 series washer will get stuck in between cycles
Sounds like the timer has failed. It's a common problem.
Part number 8545379, $83.69 from SearsPartsDirect.com
1helpful
Kenmore series 80 washing machine mod.# 11026842692
could be a broken 2nd rinse switch. contacts would not open up.
the noise could be coming from the gears inside the timer slipping.
if it is a kenmore, usually, it has these plastic cover on each side of the control panel. pry it slowly and lift it to exposed a screw that is holding the panel.
tnx 4 using fixya,
drcool
I also need the answer...
where is the lint trap located
Alexander
vince
