I have a Mitsubishi WD-65737. I replaced the bulb about 4 months ago (whole lamp assembly with housing). All has been good until today, now it turns on and runs just fine for about one minute then shuts down. When this happens the status light stays red. When I run a self-diagnostic (holding the
Make sure the lamp is a real osram or phillips lamp. IT should say Osram PVIP or Osram Neolux.
If not get a new lamp. Otherwise try reseating the lamp.
Testimonial: "At this point this is nost helpful. I asked this question 5 months ago."
SOURCE: mitsubishi dlp does not get picture
the plug the connects underneath is not connecting right you have to get at the plug and seat it correctly
SOURCE: green status light keeps blinking after lamp replacement
continuous blinking green light indicates that the capacitors have failed on the DM pwb. You need the V26 DLP DM repair kit which is available at the following link under their repair category.
http://servicemanuals.vstore.ca/
SOURCE: Mitsubishi WD 62327
Yes this is the signal for a bad lamp. Other things can cause this. 1. Look at the new lamp. make sure it still looks good. not broken with little glass pieaces in it. 2. When you turn on the tv, put your ear to the lower back part of the tv near the middle. Listen for the start up of the color wheel (a low high pitch sound only at the start up of the motor). If this is good you will here a ticking sound only if the lamp dose not light.
Now with all this info. If the lamp lights (as seen from the back of the set) and goes out after a few seconds and you did not here the color wheel spin up, the color wheel is bad.
If you here the color wheel spin up and no ticking sound, the Ballast is bad.
The ballast part no. 939P978010
The color wheel is not avialable from Mits. You will have to replaced the light engine. It cost to much. Just buy a new tv.
My best gess is the Ballast.
