Question about Logitech Cordless Desktop MX3200 Laser Keyboard Mouse
Keyboard not working
My mouse works but not the keyboard I have installed new batteries
  • jonasut Sep 18, 2008
    I have the same problem. The mouse works ok but not the keyboard. It seems that the connection is ok because the zoom and standby button work, but all other buttons do not work at all.
  • starr11 Sep 20, 2008
    I also have this problem. I have tried reconnecting, new batteries, different port and all the same results. Mouse works fine, and keyboard won't respond.
On another thread i found the solution:
[Ctrl]-[Alt]-[F12] (must use the left [Ctrl]-[Alt] keys, not the right)
Push the Connect button beneath the keyboard, then the Connect button on the USB Receiver, then the [Esc] key on the keyboard.
This will unlock the security encryption on the keyboard. You may need to reconnect the mouse afterward too.
Posted on Sep 20, 2008
I want a solution i am offering one
Posted on Sep 16, 2008
Keyboard doesn't work. mouse is ok battery new
You say the mouse works OK. You also said the battery is new--I take it you are talking about the keyboard battery.
1. Is the keyboard battery installed correctly?
2. Have you pushed the "connect" button on the USB antenna?
3. Have you pushed the "connect" button on the bottom of the keyboard?
If you have done these 3 things, you should be up and running. If not, you might go into the device manager and delete any keyboard there and try restarting the computer to see if the keyboard is detected.
Oct 07, 2010 | Inland Pro Keyboard
My Trust wireless keyboard and optical mouse will not install when I start my computer
Be sure that you have new batteries installed in the keyboard and the mouse.
After booting up into windows, plug them back in and see if windows detects them, if it does detect them it should install the drivers for the mouse and keyboard. If it doesn't then go here and download the drivers for it:
http://www.trust.com/products/productdrivers.aspx?artnr=14627
If after downloading and installing the drivers the mouse or/and keyboard still doesn't work, hit the connect button on the receiver for the keyboard and mouse. Then hit the connect button on the keybyoard and mouse.
This will make sure that both the keyboard and mouse synch with one another. If they still won't work after all these steps then you know for sure that either the keyboard and/or mouse are definitely bad and would need to be replaced.
Jan 11, 2010 | Trust Wireless 11676 Keyboard
My dell wireless keyboard doesn't work the mouse works. They are linked into the same USB reciever. There is a red light for the keyboard and green for the mouse....I have tried all windows diagnostics,...
try to delete the Bluetooth keyboard and mouse, then search/create a new device and see if they are detected. if yes, just follow the instruction on installation. else, there could be a problem on either of them. hope this helps
Oct 31, 2009 | Dell Wireless Keyboard Optical Mouse w0147
Inland 601781 wireless keyboard stopped working.
Remove the battery of the keyboard and install new one and then press connect button from the keyboard side and the receiver side also.
Oct 20, 2009 | Inland u-Touch Multimedia Keyboard/Mouse...
I had a new hard drive installed on my computer and now my keyboard will not work. My mouse does, but not the keyboard. I temporarily have a wired keyboard hooked up. I can't seem to reset the wireless...
i found 2 computers in the trash. the keyboard and the mouse does not work with a hard drive in it.i cant even get into the bios. when i remove the harddrive. the mouse and keyboard works fine. what could be the problem.
Oct 10, 2009 | Dell Wireless Keyboard Optical Mouse w0147
Gear head kb5500w kmouse works keyboard not
If you still have the mouse and connector, ill purchase them from you. I bought the set, but it turned out the only thing in the box was the keyboard.
Aug 06, 2009 | Gear Head WIRELESS keyboard/Mouse
Same problem...
get a new keyboard at walmart they are only about 12 dollars
Jul 02, 2009 | Logitech LX 300 Keyboard/Mouse
Logitech wireless keyboard not working
After changing the batteries and cleaning the corrosion out of the battery case, I pressed the connect button on the Logitech receiver, then the red restart button on the underside of the keyboard and it was fixed!
Mar 25, 2009 | Logitech Wireless Access Duo Optical...
Keyboard does not work
i would suggest starting over.. uninstall the drivers for the keyboard mouse and go download the new ones from the manufactures website and fallow the instructions. typically they want you to install the drivers first before plugging in the wireless receiver. i hope this helps.. good luck.
side note- if your having the same problem with 2 diffrent wireless keyboards. you might have some interference from another wireless device. i.e. cordless phone, cell phone. so you might troubleshoot that if the drivers dont work.
Jan 22, 2008 | Computers & Internet
Logitech cordless mouse and keyboard installation
You probably already done this but try pressing the receiver button and while it is flashing turn the board over and press the small reset/connect button on the bottom of the board and also the reset/connect button on the bottom of the mouse. It should work okay after that. here is hoping that helps. Bud
Dec 20, 2007 | Logitech Cordless Desktop MX3200 Laser...
Logitech Cordless Desktop MX3200 Laser Keyboard Mouse Logo
297 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
