Question about Apple iPod MP3 Player
New computer my old hard disk crashed with itunes on it, and is not recoverablbe and I have no back up. How can i get the entire library off my ipod and back onto itunes on my new computer pleease?
    Problem Solver:
  • 5 Answers
Re: new computer
Same thing happened to me. I also used Ipod acess. It can be download here. You can use it on Xp and vista and Macs. Luck
Posted on Nov 17, 2007
  • 35 Answers
Re: new computer
I use a program called Ipod Access. It lets you transfer from the Ipod to the computer. Very easy to use and very helpful program. Good luck
Posted on Nov 11, 2007
0 characters
3 Points
I have 4 ipods and want to use them on itunes with different playlist
you will need to download and have 4 separate itunes installed either on one or more computers if you want to have separate lists of playlists othewise you you will have to have all playlists on one installed itunes
never select update to another version of itunes
as i have done previously you will lose all songs loaded and you will have to load all music on again to sync your ipod
unless you back your music up to a disk/s
open Itunes in the top left hand corner select file from the drop down list you will see Library click to open then you should see back up to disk then more options back up entire library to disk
hope this helps you
Mar 22, 2012 | Apple iPod touch
How to transfer songs from Appleipod to Laptop and itunes library
There is a guide for you
Here is another one
Jul 23, 2009 | Apple iPod nano
How do i transfer my Ipod libary from one computer to another?
In your case, you can use an iPod Transfer tool to transfer iPod library to a new PC. You can have a try of this Wondershare iPod Tranfer, by which you can transfer iPod library to new PC, tranfer music/video from PC to iPod directly without using iTunes. You can free download it at:
Hope that helps.
Jun 06, 2009 | Apple iPod touch
IPOD how to move music
Follow these steps it will help you to copy music to pc
Open iTune
confirm that your iPod is configured to enable disk use. Essentially this means that your new computer will recognize your iPod as a USB device device or a external drive.
Enable disk use if necessary. Connect your iPod to your old computer and open iTunes. When iTunes has loaded, select your iPod and display "Preferences" in the main window.
Click on the "Summary" tab and select "Manually Manage Music." You should see a check mark in the box next to "Enable Disk Use." If you don't see it, then just check that box yourself. An alert will display informing you'll now need to manually unmount the iPod as well as ejecting it in iTunes before disconnecting it from the computer.
Hit "OK" and click "Apply Preferences."
Consolidate Music
Move all your music to one place to make the transfer easier.
Navigate to the iTunes Preferences menu. In Windows, this menu is located in the Edit menu, while on a MAC it's simply it's own menu.
Go to the "Advanced" tab, then "General." Check the box next to "Copy Files to iTunes Music Folder When Adding to Library" and click "OK." iTunes will copy all of your music to the hard drive of your computer. This shouldn't be a problem unless you don't have enough disk space.
Go to the "Advanced" tab and then "Consolidate Library." Read the message that warns you that this step will place all your music in the iTunes folder and that it can't be reversed. Click "Consolidate."
Determine Storage Capacity
Make sure there's enough space on your iPod to hold the iTunes music files. In essence, you will be using your iPod as an external storage drive to bring your iTunes library to the new computer. Without a large enough storage capacity, this can't be completed.
Determine how much space is available by opening iTunes on your old computer and checking the size of the library. Click on "Music" and make note of the amount of space your library takes up. Then connect your iPod, click on it in iTunes and note the amount of free space indicated at the bottom of the pane.
Calculate to make sure that the amount of available space on your iPod is greater than the space required by the iTunes library. If not, you'll need to free up some space.
Free up space by clicking on your iPod in the Source pane and then clicking on "Music" or otherwise navigating to the contents of your iPod. Click on any song in the main library window and go to "Edit, then "Select All."
Be prepared to lose any music not contained by your iTunes library if you haven't been updating automatically, because that music isn't on your computer and will be deleted. However, if you've been updating, there's no need to worry. Press your keyboard's "Delete" button and click "Yes" when you receive the confirmation message.
Copy and Backup
Exit from iTunes and locate both your iPod and your iTunes folder. On a Mac, the iPod should be visible on the desktop and the folder is "/Users/username/Music." In Windows, the iPod is located in "My Computer" and the folder is "\Documents and Settings\username\My Documents\My Music\." Drag the folder to the iPod and wait patiently as the data transfers.
Copy your iTunes folder to your iPod. Drag the folder to the iPod and wait patiently as the data transfers. When it's done, eject the iPod from iTunes and disconnect the iPod.
. Connect your iPod to your new computer and backup any music that's in your new iTunes library. Go to "Preferences," "Advanced" then "Reset." Click "OK." Then navigate to "Advanced," "Consolidate Library" and click "Consolidate."
Copy your music to your new computer. Locate the Music folder on your new computer--it will have the same name as on the old computer--and drag the iTunes folder from it to the desktop. Find your iPod, double-click to open it and drag the iTunes folder copied from your old computer to the new computer's iTunes folder.
Wait as the music is copied to the folder and then open iTunes. The music and all of its accompanying information should sync without problem.
Dec 15, 2008 | Apple iPod nano 3rd Generation
Sync Old iPod Shuffle & iPod Nano
Are you saying, that you want to know if you can use your old iTunes that you had for your shuffle, on your new ipod? If so, the answer is yes. Copy your itunes music on a pordable disk. When you plug your ipod into your computer, it will recogonize that it is a different ipod. A box will come up and ask you if you want to have a new library. Click yes and then you will have a new library. Put your disk(s) in and copy them over to your itunes.
I hope this helps, but I'm sorry if it doesn't. I didn't exactly get what you were saying. I haven't exactly tried this, but I think it will work. Please rate my solution.
Oct 18, 2008 | Apple iPod nano
IPod A1136
You Itunes purchases have to be restored to the hard drive as well. Otherwise you will have to repurchase them. Itunes doesn't allow you to copy your purchased songs from your Ipod into the library on your hard drive. You can play them from Ipod as long as you enter you Itunes account information. Make sure your Ipod is set to manually manage music or you will wipe out the songs.
Aug 13, 2008 | Apple iPod MA446LL/A MP3 Player
Connecting ipod to a new laptop
You can actually (or could have) transfer the songs from your
Laptop & iPod by using you iPod like a removable
Hard Disk Drive
Here is the Apple sanctioned method:
Note: While you can use the Transfer Purchase From iPod option under the File menu to copy iTunes Store purchases from the iPod to another computer you can't transfer songs from other sources from the iPod library to iTunes
So you'll need to follow the steps below to use iPod as a hard disk to transfer music files from one computer to another. This process will require the use of iTunes 7 on all computers. Any computers running iTunes 6 or earlier will need to be updated to follow these steps.
Once you have the files transferred, you'll need to authorize any iTunes Store content. If you won't be using your old computer, you'll want to deauthorize it.
Important: Windows operating systems don't recognize Mac OS-formatted disks (HFS or HFS Plus formats), so you can't use a Mac-formatted iPod to move your music to a Windows PC.
Switch the iPod to manual update and enable disk use The first thing you need to do is make sure have configured your iPod to enable disk use. To do this:
  1. Open iTunes on your old computer.
  2. Connect your iPod to your old computer and wait for it to appear in iTunes.
  3. Select your iPod in the Source pane under the Devices section to display your iPod preferences in the main library window.
  4. Click the Summary tab in the main iTunes window.
  5. Click the Manually manage music button. Changing from automatic updating to manual puts a check mark by Enable disk use. A message says:
"Disabling automatic update requires manually unmounting the iPod before each disconnect."
If you need to copy from old computer:
Copy iTunes folder to iPod To copy all your music files (including the library file that holds all your playlists and other settings) to your iPod:
  1. Quit iTunes.
  2. Locate your iPod:
    Mac OS X: On the desktop
    Windows: In My Computer
  3. Locate your iTunes folder:
    Mac OS X: /Users/username/Music
    Windows: \Documents and Settings\username\My Documents\My Music\
  4. Drag the iTunes folder to the iPod. This can take a while if you have a lot of songs.
  • When the copy completes open iTunes.
  • Click on the iPod in the Source pane
  • Click the Eject button in the lower right corner of the iTunes window.
  • Disconnect the iPod from the computer when the "Do not disconnect" message no longer appears on the iPod screen.
Copy music to new computer To copy all your music files (including the library file that holds all your playlists and other settings) to your new computer:
  1. Locate your Music folder (Mac OS X) or your My Music folder (Windows) on your new computer:
  2. Drag the iTunes folder in this location out to the desktop. 300173_10.gifFrom the My Music folder to the Desktop on your new PC
  • Locate the iPod on the new computer:
  • Mac OS X: On the desktop.
  • Windows: In My Computer.
  • Double-click on the iPod to open it.
  • Drag the iTunes folder from the iPod to the Music folder (Mac OS X) or My Music Folder (Windows) on your new computer. This can take a while if you have a lot of songs.
  • Open iTunes
    There you go. All your music, playlists, and other information like play counts and ratings have all been moved from your old computer to your new one.
If that doesn't cover it fully..... wow!
Feb 12, 2008 | Apple iPod nano
Apple iPod MP3 Player Logo
37 people viewed this question
Top Apple MP3 & Digital Media Players Experts
 Mike M
Mike M
Ron Dufek
Ron Dufek
Raisin Brann
Level 1 Expert
Are you an Apple MP3 and Digital Media Player Expert? Answer questions, earn points and help others
