all-in-one 5510 started printing off the edge of the side of the page when I went to change the cartridge, both color and black was removed and taken to be refilled but when reinstalled the carrier was shifted back into shutdown position the carrier was pulled back to reinstall position as it had change itself from that position with the door open by itself, when the cartridges were placed back in the carrier they would only print one page at a time and asked for alignment each time, hit cancel, and OK, then it would print one page but it started at the top on "copy" a page to run off the side of the page diagonally, how does it get corrected?
it keeps saying scanner failure power off and then on again .not able to read the picture.unable...
(More)
it keeps saying scanner failure power off and then on again .not able to read the picture.unable to retrieve image from device .
printer is not working paper will not feed copier and scanner notworking .changed ink cartridge...
(More)
printer is not working paper will not feed copier and scanner notworking .changed ink cartridge after pausig printer and it has not worked since.
I have a hp psc 750 printer/scanner/copier. I want to scan but keep getting scanner error. What...
(More)
I have a hp psc 750 printer/scanner/copier. I want to scan but keep getting scanner error. What causes this? How do I fix?
got a Hp 750 that does every thing except scan and print, it will scan into computer but not scan to...
(More)
got a Hp 750 that does every thing except scan and print, it will scan into computer but not scan to print
