Unable to remove message as dregs drawer is completely empty
SOURCE: Emtied the dreg drawer when the SAECO machine was off.
Chenk the back of the area for the drawer, there might be some grounds preventing the draw from going all the way in to tell the microswitch that it is in place.
SOURCE: dregdrawer full
Check the back of the drain tray make sure there are no grinds. Then we will have to test the micro switches, remove the drain tray and dregs drawer, insert tray without the drawer, to see if you get an error. A more complicated way is to have the door open place tray minus drawer in machine, then using a small stray or plastic knife, activate the microswitches.
SOURCE: machine shows message 'dregdrawer full'
Hi
When you go to empty the dredge drawer you must leave the machine on. When you remove the dredge drawer it will say dredge drawer missing. Leave it out at least 15 seconds so the machine knows you are empting it. When you insert it again the machine will count about 24 cycles and tell you to empty it again. Its a counter.
