Question about Maxent MX-50X1 50 in. Plasma Television
Power Swtich Brand New TV out of the Box. I plug it to the wall and it will not turn on. This is a Maxent MX-50X1 50 . I can't find a power switch on the sides or top, does any body have an idea of what it could be? ? email me to
There is an OFF/ON button near the inlet plug.. Turn that on...
Posted on Feb 18, 2009
I have a Maxent MX-26X3 Television and I cant get it to connect to the local channels when I plug in an antenna. What am I doing wrong?
Do you have a digital converter box? Its a smaller block square box that connects to the wall and the tv connects to the digital converter? I you do not have a digital converter that is most likely your problem. Not a gurantee but since they did the big digital signal switch, you now need these converters. Hope this helped
Oct 26, 2012 | Maxent MX-26X3 Television
Need the Dish Network Remote code For Maxent MX-5020HPM
We do not have any codes listed for that TV brand, try the steps below for a Power Scan this should resolve the issue.
Power Scan
1.) Hold down the clear "TV" button on the remote for four seconds, then press 500 pound ( #) 2.) Hold down the clear "TV" button on the remote for four seconds, press the big power button once. 3.) Press the channel up button once per second until the TV turns off then press pound (#).
Daniel Busa
DISH Network
Customer Service
Apr 18, 2011 | Maxent MX5020 50 in. Plasma Television
I have a 42" Maxent plasma tv. When turned on,
one or your tv mainboard was crashed, change it with new one
Jan 18, 2011 | Maxent MX-42HPM20 42 in. Plasma HDTV
Maxent 32" power problem
I had a similar problem with my Daytek LCD TV after a power outage.
A quick read of the manual showed how to do a reset on power up.
That solved my problem and everything worked okay after that.
Jun 26, 2010 | Maxent MX-32X3 32 in. HD-Ready LCD...
Is there any way to connect basic cable to the tv without using a converter box or anything else
Recently, I dropped HBO with my cable company and there dont have a box. Since the Maxent 42 is only a monitor and doesnot have a tuner...there is no where to plug cable from the wall to the tv.
Solution...plug cable from wall to VCR/DVD and then use RCA cables (Red,White and Yellow cables) from output from VCR/DVD. works great.
Nov 22, 2009 | Maxent MX-42HPM20 42 in. Plasma HDTV
Brand New and already broken
There is a short on one of the boards. The power supply may have also been damaged. You should take the set back to the dealer for an exchange.
I would sugget to buy a quality brand name if you want high reliability.
Jerry G.
Jun 20, 2008 | Maxent MX-42HPM20 42 in. Plasma HDTV
Maxent MX-42XM11 Television Power Problem Problem
i was having the same problem and the power supply board was out
Jun 06, 2008 | Maxent MX-42XM11 Television
Maxent MX-50X3 50 in. HDTV-Ready Plasma
Yes I had this problem. Unplug the power cord for 1 min then plug it back in. The tv will reset and the buttons then work again.
Sep 26, 2007 | Maxent MX-50X3 50 in. HD-Ready Plasma...
Maxent MX-42vm10 42" Plasma
Generally, if a Plasma Tv is not coming out of standby, it means either the main board is faulty (most likely case) or Power Supply Board is not giving enough power to Main board to switch on the TV. In your case, I think it's the main board (aka Motherboard). Sometimes it's hard to tell to whether ceremic fuses are blown off by looking at them, so it's best to check with a multimeter. Check the fuses in the PSU and also whether it's outputing correct voltages. Also, can you hear a clicking noise right after you've switched on the TV or pressed the power button in the remote to make the Tv go from standby to ON. A clicking noise means one of the boards is shorting out. In your case, I don't think you'd hear a shorting out clicking noise, and I think replacing the Main board will get you out of standby.
Jul 27, 2007 | Maxent MX-42VM 42 in. Plasma HDTV
Maxent MX-50X1 50 in. Plasma Television Logo
144 people viewed this question
Top Maxent Televison & Video Experts
Michael Harrier
Jaime Hernandez
Are you a Maxent Televison and Video Expert? Answer questions, earn points and help others
