1988 stnd cab, 5.7 liter 350. Truck sat for 8 years. Got it running, ran good for 3 weeks. Started losing power and not running well until it got up to temp. Once at temp it ran fine. Replaced catalytic converter, ECM valve, and cooling valve? Computer was throwing a "15" fault code which said it was the cooling valve. Now it idles ok, runs in neutral, when i put it in gear it wont stay running.
I had a very similar problem except I would have to throttle my truck just to keep it running. It wouldn't even idle. If I were you check the spray pattern on your fuel injectors. It should look like a nice misty cone. Youy dont want lage drips of fuel, you want a mist. Also cut into your fuel line to test your fuel pressure. It should be around 9-13 psi. My truck had 3psi. I then replaced the fuel pump and the problem was solved. Hope this works for you.
