Question about Frigidaire ATF6000ES Front Load Washer
LOC-Can't start my washer
I can't start my frigidaire washer. It shows LOC on the indicator. How do I fix it?
Ok, press Options and Select at the same time and hold for 10 seconds until "LOC" is no longer displayed. Your control lock was engaged.
Posted on Nov 11, 2007
Loc error code on Frigidaire frontloader
To avoid having someone accidentally start or stop the washer, press OPTIONS and Select at the same time and hold for about 10 seconds until the Control Lock) lights up. "LOC" will be displayed alternately with the estimated cycle time. Turning the Cycle Selector knob or pressing any button will produce flashing indicator lights and/or beeping. To unlock the controls, press and hold OPTIONS and Select for about 10 seconds. Frigidaire GLTF2940ES3 Quick Start Manual Page 3
Jul 24, 2014 | Frigidaire GLTF2940ES Front Load Washer
Washer won't run. It beeps 3 times and flashes "err" and "LOC".
HI. The term"LOC" will be an indication of the "Child Locking" feature that has been activated either by mistake or intentionally. This is a safety feature to prevent unwanted starts when children are present.
To unlock the controls,press "Options and Select" at the same time and hold for 10 seconds until ”LOC” is no longer displayed.
  • NOTE_ If the release procedure doesn't unlock the unit and the letters LOC continue to appear, this will be a strong indication of a severe fault within the main control board. try to power cycle the unit if this is the case. if the power cycling doesn't produce good results, replace the main control board assembly.
Aug 14, 2010 | Frigidaire ATF6000ES Front Load Washer
What does loc mean
"LOC" indicates that the control panel settings are locked. Press the SELECT and OPTION button simultaneously to toggle this 'feature' on or off. This will fix the issue.
Thank you !!
Jul 18, 2010 | Frigidaire GLTF2940ES Front Load Washer
I have a Kenmore washer (417.44082400), which is displaying alternately the following information: ERR LOC 37 The 37 indicates the usual minutes for our customary Permanent Press cycle. When Start is...
The LOC code merely means the control responded and locked the door. You'll find a tech sheet under the top panel of the machine to help guide you thru the diagnostic process, which is fairly involved.
LOC means it thinks the control panel is locked. This gives the ERR indication when you push the buttons. To unlock it you need to hold down the Options and Select buttons together until it reacts.
I know this may seem silly but - On the top right back corner of your washer hit it with medium force with your fist, this helps.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 07, 2010 | Frigidaire Affinity ATF7000E Front Load...
ERR LOC on display
Your door lock switch needs replacing.
Jul 07, 2010 | Frigidaire GLTF2940ES Front Load Washer
Loc on dryer
Thank you !!
Jul 06, 2010 | Frigidaire ATF6000ES Front Load Washer
When trying to start washer LOC shows on the display and washer wont start and we're unable to change settings????
Unplug the washer power cord and plug it back after 2 minutes and see if the washer reset it self. I think it will.
Oct 01, 2009 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire washer will not start. Get err and LOC codes.
All the lights are on, but the door lock. We have unplugged it, doesn't help. Our washer is the front load, model LTF 2140ES0.
May 18, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
LOC code flashing on washing machine
Pressing the options and select buttons simultaneously for 5-10 seconds worked. For me it happened this way: on the first attempt, with the indicator lights already "timed-out" and off, pressing and holding the options and select buttons simultaneously for 5-10 seconds caused the lights to come back on and flash the "LOC" code again. But holding the options and select buttons together for 5-10 seconds a second time caused the indicator lights to stop flashing, and allowed me to start the cycle.
Dec 01, 2007 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
323 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
