Most starter relays are part of the starter motor assembly.
Also known as the solenoid.
(This way it serves 3 purposes.
1. The Relay section uses solid copper Contacts for Less volt drop at the high current that a starter motor draws.
2. The Solenoid section is the Mechanical Plunger that engages the cog to flywheel.
3. The Motor spins because the copper contacts are a super connection supplying 100+ Amps)
Does the battery go direct to the Starter Mptor?
Is there a small wire next to where the Battery connects?
If so then this is the relay activation wire (12v to pull relay in)
Happy Starting
External Relay Basics
Same but bigger for Starter Motors
RELAY BASICS
Starter Solenoid - A Gutsy Relay
Testing and replacing pre engaged starter motor solenoid
How To Test Car Starter With Screwdriver And Jumper Cables
SOURCE: how to remove the trim around your radio on a 1998 oldsmoblie intrigue
Open the console lid an remove the screws at the front of the console and pull the console plate up to release the clips and slide up over shifter. Pull rearward to release the clips that retain the instrument panel accessory trim plate to the instrument panel.
