Help please
Turn off the machine - open the service door and see if u can tilt out the tall dregs container and remove it and the drawer. You need to get it past the coffee par rejector flap on the left of the brew group. It sticks out half way into the left hand side space.
Close the door and put in only the tall dregs container. It has a metal bit on the back the releases a magnetic reed switch inside the machine.
Turn the machine on and you should hear the drive rotor moving. As you move the dregs container back and forth, the drive motor should turn. The idea to is fool the machine into getting the water inlet point in the back of the brew group to clear the boiler pin in the back of the machine so the brew group can be removed.
SOURCE: brew group on saeco odea giro wont go back into machine
try to put in the dregbox to the machine, close the door and power on the machine. When the machine not make any noise, open the door and put in the brew group.
