Question about GE Profile JTP95 Electric Single Oven
Display My oven will stop working and start to beep.  On the display will be either F2 or F3.  Please tell me what that means.  Thankyou
Hello, working for GE I hear numerous questions in regards to these types of errors.
The first thing to do would be to check the Use/Care manual for the unit. Go ahead and input your full model# in the SEARCH box located on the main site here :
From there you can click on your particular model (I chose the BB or black model since you didn't specify"JTP95BABB") and then on that unit's page there will be a tab in blue that says "Product Documentation."
From there, you can see an Adobe Acrobat type copy of the Use and Care manual for that appliance. The FAQ on errors is normally listed near the Warranty information, to try and reduce the amount of cost to consumers on non-warranty covered and/or calls in which a tech really isn't needed to assist you.
Sometimes, a fix can be as simple as resetting the power breaker for the appliance.
In my experience, an F code of any kind will either go away with a resetting of the breaker (wait approximately 5 minutes before turning power back on!) or unfortunately, it will require a licensed technician to replace it (consumers replacing certain parts can void the warranty please make sure to check your use and care manual and call the G.E. Answer Center, or "GEAC" as it's called internally, for any questions regarding warranty coverage.
Posted on Nov 10, 2007
Oven will say F3 and shut down what does F3 mean no book?
Kenmore' F2 or F3 usually points to an open oven temperature sensor. If that is the problem, it's not an expensive repair.
Mar 02, 2014 | Kenmore Ovens
F3 f4 gaas oven when preheated these numbers appear it beeps and shuts off
Hi, replace the oven temperature sensor if "F2," "F3" or "F4" is displayed. "F2" indicates the oven temperature is too hot and the oven temperature sensor is suspect. "F3" or "F4" indicates the oven temperature sensor or shorted or open.
Jan 22, 2011 | Magic Chef Ovens
Amana Self-cleaning Oven flashes F2 and F3 and beeps. It doesn't get real hot. Although it does heat up not the appropriate temperature.
Hi, F2 error code on the Amana Oven means "Oven too hot" You have to replace Oven temperature sensor to fix it.
F3 error code means "Open or shorted oven temperature sensor". Yo also have to replace Oven temperature sensor to fix it.
Summarily, both code has to do with the temperature sensor which you need to replace...
Oct 23, 2010 | Amana Ovens
When I turn the GE oven on sometimes it works fine other times it will shut off. When it shuts off it will give the F2 or F3 error sign.Can you please tell me what this means? Thanks
Hi, the F2 Error code means the oven has detected an excess temperature condition. Most often this is due to a bad temperature sensor - the sensor costs about $75 from an online repair site.
The "F3" error code means the oven sensor is open, I suggest you flip breaker off then back, on Re check for error, if OK fine if not turn back off and fix or call for service man...
Oct 06, 2010 | Ovens
Beeping with 'f2' & 'f3' message when cleaning but did not finish cleaning. Oven now cooled but still locked.
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%$@#
May 25, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
-F3- code on display panel
Replace the oven temperature sensor. It protrudes from the back wall in the oven. About a 1/4 inch metal stick.
Mar 26, 2009 | Cadco Ovens
F2 and F3 error messages on Tappan wall oven model 12-4980 10/03
These are the F2/F3 error codes for a Tappan oven
F2 Oven too hot Check Bake function, if OK, replace oven temperature sensor F3 Oven temperature sensor open Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor
please take the time to give this solution a fix ya rating.
Feb 09, 2009 | Tappan Ovens
F2 and F3 code appearing along with annoying beeping
i think f3 error code has something to do with the temp probe maybe it is the problem. the temp probe is located if you open the door directly in the back wall. it looks like a prong. should read 1100ohms the f2 error code though usually has something to do with the keypad i would check all the connections maybe they are loose.
Jan 04, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
GE Oven displaying both F2 and F3 error codes; bad ERC or temp sensor?
F3 is Open oven temperature sensor circuit.
F4 Shorted oven temperature sensor circuit .
F7 Component failure.
To fix this you need to read oven temperature sensor circuit at oven temperature sensor ( approx 1000 ohms at room temp); check for cut or pinched wire or loss of contact, if wirings are ok, then replace the probe.
Oct 28, 2008 | GE JRP15 Electric Single Oven
GE Profile JTP95 Electric Single Oven Logo
115 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
