Question about Uniden Cordless Phone
Cordless Phone---People can't hear me
When I call someone they can not hear what I'm saying and I'm yelling and then they can hear. I do not know how to turn the volume up on the phone where I speak into. I can turn the hearing volume up so that isn't my problem.
SOURCE: I can hear caller but they can't hear me
I had the same problem with two of these handsets. I am not certain of the cause, but based on the fix, I believe water got into the microphone holes and perhaps mixed with a water soluble glue that stuck the felt cover to the microphone. I fixed the problem by removing the battery, opening up the phone (slide the battery cover off and removed the 4 screws) and snapped open the plastic encasement. Then I remove the two screws toward the top (toward antenna) of the circuit board. This gave me access to the microphone which is on the underside of the circuit board (very bottom of the phone, below and on the opposite side of the plastic jumper for the battery) which had a thin black felt cover covered in a sticky residue that was covering the microphone diaphragm. I removed the felt and then used a cotton swab with rubbing alcohol to remove the residue from the diaphgragm. I used compressed dry air to remove any dust from the diaphgram. With the 2 screws, I secured the circuit board back in, snapped the plastic case back together. Then I finished off with putting 4 screws in the case and putting the battery in. Now other parties can hear me just like they used to when the phone was working.
Posted on Jan 19, 2007
SOURCE: Uniden cordless phone - model DSS7855
Press and hold "end" and "#" for more than 5 seconds this will de-register your handset without the base unit.
see for more info.
Posted on Mar 05, 2008
SOURCE: idect x1 cordless phone
the cordless connected on ups rings periodically without being called
Posted on Mar 08, 2008
SOURCE: model 28112ee2-4 dect 6.0
SOLUTION: My handsets stopped ringing after power was stopped to the main base, too. I put one on the main base and that one started working but the others still didn't work. So I put the other phones on the main base while I called from my cell and let it ring. The other phones started to ring and work again.
Posted on Oct 18, 2008
  • 84 Answers
SOURCE: cordless phones expandable to 4 with T-coil
Any Uniden DECT 6.0 series phone will have T coil and can expand to either 4 or 5 handsets.
Posted on Feb 27, 2009
  • 84 Answers
SOURCE: uniden 5.8 ghz phone. Can you turn the ringers off and how ?
On most of the phones you just keep pushing the volume down button untill it turns off. On some models there is a "Do not disturb" feature, usually it is a soft key feature so look on the LCD screen. Also, for the person that can't turn the ringer back on, just push the volume up key untill the ringer is at the level you like.
Posted on Mar 24, 2009
0 characters
1 Points
Handset on panasonic cordless only works with headset
It appears there is something internally wrong with your handset. We recommend you use the below link to setup service.
Apr 28, 2014 | Panasonic KX-TG5422M Cordless Phone
Cannot retrieve messages
shut it down and open it will work
Dec 08, 2013 | Uniden DECT 6.0 Cordless Phone ID
People say they can't hear me on th t7208
If there is another phone that this doesn't happen on, try changing your handset with that one. If this doesn't fix the problem it most likely is your telephone.
Sep 27, 2013 | NorStar T7208 Corded Phone
I have lost my manual and do not know how to set up my answering machine part of my v-tech cordless phone/answering machine. I have successfully made a personal recording on it and I hear it come on when...
Since you didn't specify the model of your VTech phone, please enter the model number into the search box at
to get the manual.
Sep 06, 2011 | Vtech DECT 6.0 Cordless Phone with Digital...
My phone rings but i can't hear anything on the end
i have a GE 6.0 cordless telephone, i know tha it's ringing the number comes up on my television but I can't hear it ring?
Sep 23, 2009 | Uniden DECT 6.0 Cordless Telephone...
Having problems with phones
Na. Just remove the battery from all the phone and put them back in. Then do a factory reset on each handset...
Sep 03, 2008 | Uniden 2.4 GHz Cordless Phone System
GE Cordless phone "Do not Disturb" setting
There is a button on the main base that says " Do not disturb" my 4 year old son must have pushed it. It was an easy solution.
Thank you!
Jun 16, 2008 | Uniden Cordless Phone
see for more info.
Jan 21, 2008 | Uniden Cordless phone EXS9950
Cannot hear person calling
I am having the same problem with the same model phone! The line works with another phone but not with the GE cordless. If I call someone with the GE cordless they can hear it ring and hear me talking but I cannot hear them speaking. Silver Spring MD
Sep 06, 2007 | GE 21028GE3 Cordless Phone
Uniden Cordless Phone Logo
228 people viewed this question
Top Uniden Phones Experts
Dave Ellis
Are you an Uniden Phone Expert? Answer questions, earn points and help others
