Question about Weber Q Grill
Where does the L shaped metal bracket about 3in wide, with 2 offset screw holes mount at?
I had to take it apart to clean it, it wouldn't lite, and now I forget where this part goes. Im thinking it is on the side of the controls.
I need help finding mounting screws and bolts for my 47" 1080P 120HZ LCD w/2YR. The table that I bought for the tv dindn't bring them.
If you want to put the LCD on a stand you"ll need the original that screws on the bottom. best way to mount LCD is to the wall or on a metal stand. There are holes on the back of the LCD to mount the bracket most brackets have a lot of holes just move the bracket up or down until two line up. The screws are almost all metric coarse thread and usually are included with the bracket kit. I got my kit at Wal Mart
Apr 18, 2011 | Televison & Video
Instalation Instructions for Frigidaire Over the Range Microwave 850 Watt Model #FMT118EPB
HI,
Frigidaire makes several over-the-range microwave models that are all installed in the same manner. To install correctly, you must have at least 45 1/2 inches from the bottom of the top cabinet to the cooking surface of the stove to provide enough clearance for the microwave. The top cabinet must also be at least 30 inches wide and 12 inches deep. Find someone to help you, then follow the steps below to install your Frigidaire microwave.
Things You'll Need:
  • Stud finder or hammer
  • Screwdriver
  • Drill
Instructions
Pull your range away from the wall so you can work comfortably. If this is not possible, cover it with a drop cloth. Find and mark the locations of the studs in the wall behind the range. They will be either 16 or 24 inches apart.
Follow the instructions on the wall template to mark the location of the mounting bracket and the four anchor holes on the wall and the bottom of the cabinet. Drill the anchor holes. Follow the instructions on the top cabinet template to mark and drill the two holes in the bottom of the cabinet.
Attach the mounting bracket to the wall studs using the six wood screws included with your microwave. Screw the toggle nuts onto the toggle bolts and push one through each of the four drilled holes. Screw each toggle bolt until the nut is snug against the inside of the wall.
Pick up the oven with your helper. Plug the oven into the outlet and slide the oven onto the mounting bracket arms. Push the oven back against the wall. Tighten the two screws on the microwave faceplate to fasten the microwave to the mounting bracket arms.
Attach the louver to the top of the microwave with the three provided screws. Insert the two top cabinet screws and washers from the top cabinet into the microwave and fasten tightly.
Take care.
Jun 16, 2010 | Frigidaire Microwave Ovens
Interior door handle is broken in saab 93s how do you fix problem
I'VE GOT A SIMPLE SOLUTION TO THIS PROBLEM!
August 16, 2012
My Mother-in-law has a 2004 Saab 9-3 convertible, she wasn't able to find a fix for this problem because the plastic bracket that holds the door cable in place on the inside of the door panel broke off and it's actually part of the door panel itself. Since the bracket broke, pulling on the inside door handle would no longer pull the cable that's need to open the door.
She was out of luck and had to roll the window down to use the outside door handle to exit the car (that gets annoying really fast).
Basically without rigging it, she would've needed a replacement door panel because of this ridiculos design flaw (around $600 + installation if you could even find the panel, she couldn't because Government Motors SUCKS!) .
I simply used an L bracket that I had (can find it at any Home Depot, Lowe's etc.) and used two sets of channel lock pliers to bend it into a "squared" J shape. I then drilled 2 holes into the inside metal door frame and used 2 sheet metal screws to secure the bracket to the door frame. To make sure that I mounted the new and improved bracket that I created in the proper location (not too much or too little slack). I simply made a template with a sheet of paper by tracing where the old molded plastic bracket was in relation to the two screw holes of the door panel ( actually had to mount the bracket about an inch forward to make up the difference since the bracket is no longer attached to the door panel).
I also had to drill the **** in the bracket a bit to make sure the cable wouldn't get hung up on it when pulled, but in all it only took 15 mintues to redesign GM's crappy design.
Here are 2 pictures, hope this will solve your issue with your broken handle.
Jan 09, 2010 | 2008 Saab 9-3
Re-assembly of 99 Blazer mirror to windshield
This is a relatively easy task, the bulk of the work has been for you. The rear view mirror assembly simply slides onto that metal block that was glued to your windshield. Your mirror mount (the part that slides onto the metal bracket) may be cut differently or shaped different from the rest of that part. you simply need to line that up with the metal mount on your windshield. slide the mirror on and tighten down the set screw if you have one. I've listed the steps below
1. find the base mount for your mirror (this is the bottom of the mirror that sits on the windshield)
2. look for a cut out or flat part of the mirror base.
3. line the flat part of the mirror base with the metal mount bracket on the windshield.
4. slide the mirror onto the metal bracket (this may require you to wiggle while you slide the mirror onto the metal bracket).
5. tighten the set screw on the mirror base ( this is important because your mirror will vibrate off the bracket if you don't.
Note some mirrors slide from the bottom of metal mount bracket and some slide from the top. it sort of depends on the manufacturer and/or the way the bracket was installed.
Hope this helps
Aug 04, 2009 | 1998 GMC Jimmy
The towel bar just fell apart. The wall mounts remain in tact as well as the mounting hardware on 1 side (the piece that the bars (this towel rack has 2 bars) slide into. I can't figure out what holds...
The part that holds the bar up should either have a screw in the bottom to tighten up against the wall bracket or a hole to access a scew and turn the screw out to tighten to the wall bracket
Jun 20, 2009 | Gatco & Channel& Satin Nickel Towel Bar
Cant find how to mount amp
u need at least 2 lil L shaped brackets.flip ov er the amp and on the corners there should be a couple of holes thats were your lil L shaped brackets go.thats were mine go anyway. the brackets are about 1" .
Mar 17, 2008 | Volfenhag ZX-8300 Car Audio Amplifier
Casa Blanca Fan Installation
how wide is the beam - be more specific please.
Sep 10, 2007 | Casablanca Fan 6373T Victorian® Oil Rubbed...
Weber Q Grill Logo
97 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
