Question about Hitachi 61SBX59B 61" Rear Projection Television
Can you shut off the front control panel
We would like to shut off the front panel controls and only be able to use the remote to turn the TV on and off. Is this possible??
  • 979 Answers
No, not without doing some serious internal disabling...accordianman
Posted on Dec 24, 2007
TV shuts off with volume control
Improper signal frequency goes to the TV from the remote control. Check your remote control for fault. Gopakumar Gopalan Google
Mar 23, 2014 | Samsung PN58B550 58 in. Plasma HDTV
Tv will not turn tv on or off
If TV can be switched ON with its front panel controls, and not with the remote control; the fault should be with the remote control itself. If so, check the remote control for its infrared emission. Check it with fresh batteries. If it is universal remote control, after replacing the batteries, you have to set it up with set up code to your TV brand. Check the battery contacts in the battery compartment for any rust or dust accumulated. Clean it well before replacing with new batteries. If you wish to get more information about how to check a remote control, check the site linked here. Pull up older posts.
Dec 17, 2013 | Proscan 32LA30Q Television
I have a Mitsubishi rear projection TV (WS-73909) that didn't turn on and had a green blinking light. I replaced the 7 DM capacitors and now it turns on. Both the remote and front control panel ca
Let me know as I can look for this---the set has a keyboard lockout that is cleared by holding the menu or another front button for more than 5-10 seconds with set on---I can find the service manual and check if needed.
Nov 04, 2012 | Mitsubishi WS-73909 73" Rear Projection...
I turned tv off with remote, now it will not turn back on. i have tried remote and button on front of tv.
Check the remote with new batteries. If it do not work, remote control has the trouble. You can't switch the set ON by its front panel power switch, as it has been shut down by remote command.
Mar 31, 2012 | Symphonic WF20D4 TV
My RCA Truflat T.V won't turn on and the FPA lock is turned on, I have the original remote. what should i do?
TV won't turn on • Press the TV button. Make sure the TV is plugged in.• Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else.• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the remote control solutions on page 26.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).Buttons don't work
• If you're using the remote control, press the TV button first to make sure the remote is in TV mode.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).• Unplug the TV for two minutes and then plug it back in. Turn the TV on and try again.TV turns off unexpectedly • Sleep timer might have been activated. Go to page 24 for instructions.• KidPass might have been activated. Go to page 21 for instructions.• Wake-Up timer turned on the TV and no remote or front panel buttons were pressed for two hours.• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then
turn on again. If this happens frequently, the voltage in your house may be abnormally high or low.
• Unplug TV. Wait five minutes. Plug it in again.
Sep 16, 2011 | RCA 20F420T 20" TV
My tv says locked on the screen. i dont know what to do with the rmote. it will turn on and the channels will go up and down but says locked on the screen
Hello
As you have its remote things are easy. If you have forgotten the passoword do the following.
make sure the TV is off. Simoultaneously press and HOLD VOL. Enter a next password next time you access parential control menu.
If this does not help do the following
[1] Hold dow n [0] on the remote control and volume [2] Hod down Menu button on the front panel of the TV and 'TV' button on the remote control at the same time for at least 5 seconds.
[3] Hold down "Go Back" on the remote control hanset and "Menu" on the front of the TV at the same time for at least 5 seconds.
[4] Hold down "Eject" on the front of the TV and the "Menu" button on the remote control hanset at the same time at least 5 seconds.
Depending on the model one amoung these steps will unlock RCA tv. OK.
Nov 13, 2010 | RCA 32F531T 32" TV
Locked tv set model f19421
These are the instructions on locking and unlocking the control panel for your TV: Front Panel Lock This feature allows you to lock the buttons on the front of the TV. Even when the front panel lock feature is on, the TV operates with the remote control. To lock the buttons on the front of the TV: 1. Make sure the TV is on. 2. Press and hold the POWER button on the remote for approximately 5 seconds. To turn off the front panel lock: 1. Make sure the TV is off. 2. Press and hold the POWER button on the remote for approximately 5 seconds
Jun 12, 2010 | RCA F19421 19" TV
No control from the remote control
On these models we have found that a switch is sticking on the control panel not allowing the set to turn on. Disconnect the control panel. You will be able to use the remote on it. To find the plugs for the control panel: Remove the speaker grill and front panel, then follow the wire to the connection. Remember to unplug the set before putting your hands inside of it.
Sep 01, 2007 | Mitsubishi WS-65711 65" Rear Projection...
Front panel controls are unresponsive
Check volume up switch in front panel locked continuously. If it is not take away the remote control from the TV or remove the battery in the remote. Because maybe the remote continuously sending volume up commands. Rarely this type problem occurs through remote control also. Even problem is not sorted there is problem in EEPROM ic (memory ic). This can be sorted out by the technical persons only. I hope this useful to you.
Aug 31, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Hitachi 61SBX59B 61" Rear Projection Television Logo
35 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
