Home | Monitors | Monitor is just not tur...
Monitors
Problem for Monitors
Generic problem for all Monitors
Monitor is just not turning on
By gallagher57 on Jul 04, 2009
monitor is just not turning on
Sponsored Links
Best Solution
posted on Jul 05, 2009
Very Helpful)
gbhuvi
Rank: Master
Rating: 85%, 24 votes
is your CPU working properly?
if that the case, your monitor is in need of a service.
anyway read this.
this may help you.
reasons for why a monitor not turning on?
Reason 1: Wetness
The number one reason why computer monitors go blank is - wetness. Believe it or not, when your computer monitor is exposed to humid air, sometimes water can condense and accumulate in the monitor. This causes the monitor to malfunction and go blank. I've had this happen to my desktop PC at least three times before. What you need to do is to leave the monitor alone for some time and allow the water to evaporate. That usually solves the problem.
Reason 2: Faulty Graphics Card
The next reason why your computer monitor goes black is due to a faulty graphics card. The best way to detect this kind of problem is to connect up a new monitor to your PC, then check if you have a blank screen. If you continue to have a blank screen, then it's likely your video card is faulty.
Reason 3: Faulty RAM
This one is less obvious and less common, but it can happen. You might sometimes get bad RAM modules which prevent your PC from booting up even to the basic BIOS startup screen. To detect this kind of problem is more troublesome, you might need to remove those RAM modules and insert them into another computer.
Reason 4: Loose Connections
Another reason why your monitor goes blank is due to loose connections. The connection from the monitor to the mains is usually a culprit, as is the connection between the monitor and the video card. Check those connections before you declare your computer monitor as faulty.
Reason 5: A Short Circuit In The Motherboard
And the final reason why your computer monitor goes blank? It's possibly because of a short circuit in the motherboard. This is the most undesirable outcome of course, as you might have to replace your entire motherboard. However, it's possible that this can happen - so keep your fingers crossed and hope it doesn't happen to you.
try this.
please rate my solution.
have a nice day.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Monitors
Questions and Unsolved Problems for Monitors
Answer
half of sceen is white. under the white you see some of letters,ect.
Answer
The Luminance / Contrast panel keeps appearing every 3-5 seconds.
Answer
Does anyone Know where i might be able to get a Button board with the ribbon cable that is attached... (More)
Answer
i have accer laptop when i press the power button it get on but the screen is dark and the orange... (More)
Answer
its all in japaness i cnt understant soo plz tell me how could i use that machine if its could... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Monitors:
Top Monitor Experts
Rank: Guru Guru
Solutions: 1417
Experience: Self taught, Keep up with the manufacturer's service manuals, Beta Tester
Ask Me
Find more Monitor Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
