I bought kaspersky internet security 2013 to use on window 8.1 and is not compatible
SOURCE: kaspersky internet security 2010 and firewall issues
Your antivirus program is probably thinks that your Wireless Network monitoring program is not a possible malicious program. there should be an option somewhere to set which programs are ok and which are not.
SOURCE: cannot activate kaspersky
what is your operating system (xp/vista) start your pc as Administrator then open hosts file from C:WindowsSystem32driversetc open that as notepad...delete the line showing boxed in the image below....
remove that line from hosts file...then save it and try...wish it will help you...thanks for being with fixya...
Testimonial: "Thank You for help .... Will positively try the solution"
SOURCE: cannot activate kaspersky internet security 2010
This either seems to be a problem with a firewall or a virus itself. Here are the steps
1) Try to see if your firewall is blocking this. Go into Kaspersky and disable the firewall. Also go to Control Panel and check if Windows Firewall is still active. If it is, disable that too ... try again to activate.
2) Download the MalwareBytes anti-malware program on your computer and run a standard scan. If anythig is found, delete it and try again.
SOURCE: when i use the activation code for kaspersky
YOU CAN GET HELP FROM THIS LINK http://forum.kaspersky.com/index.php?s=236ebe1b13ced2f6b362988c3aaac243&showtopic=158280&st=0&p=1269891&
