Question about GE 25 in. Nautilus GSC3400J Free-standing Dishwasher
GE GSD2200600CC Dishwasher do not clean dishes.Removed the screen on the inside and there was no clogging.The "hole" is filled with water is that normal
  • 640 Answers
Thats normal,remove the wash arms and check for obstructions.let me know
Posted on Nov 11, 2007
Dishwasher not cleaning dishes
hi paula.
Insufficient water in the dishwasher also can cause poorcleaning. If the float gets stuck in the raised position, thedishwasher won't fill with water (Photo 3). Another likely cause is a clogged inlet screen or faulty inlet valve. ... To determine if your dishwasher is getting enough water, start a wash cycle.
Dishwasher Repair Tips: Dishwasher Not Cleaning Dishes ' Family ...
https://www.familyhandyman.com/.../dishwasher.../dishwasher...dishwasher-not-cleaning...
Dishwasher not cleaning dishes Google Search
Nov 02, 2017 | Dishwashers
Does not clean like it did soap dispences goes through the cycles does not seem to have the pressure
Hello there"
Please go thru this list that i have provided for you and check each item ok
It doesn't get the dishes clean dot_lineone.gif 1. No water
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
2. Not enough water
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
3. Clogged spay arms
There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
4. Water temperature is too low
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
5. Not enough soap
If you only fill one part of the soap cup, try adding soap to both parts.
6. Smoky film on dishes and glasses
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner. There are a few out there, we recommend Dishwasher Magic®.
Jan 12, 2010 | Bosch SHU3306UC Built-in Dishwasher
Does not cleans dishes
Hi
Thanks for using FixYa. First of all please check the Water temperature by using a thermometer inside the dishwasher to measure the water temp. It should be as close to 125 degree F to 140 degree F as possible. Now try using the temperature boost feature if your dishwasher is equipped with this cycle feature and check if this will help your wash ability issues.
Now check the Powder soap by making sure that you store your soap in a dry environment and it is not stale and clumping together. Possibly try a different detergent like a liquid or gel. Also, make sure the dishes are loaded properly, or dishwasher is not overloaded.
To check the proper filling dishwasher will fill with water up to and around the heating element. If water is more below the heating element, you may have low water pressure or a problem with the fill valve. Try & listen if it sounds like it is spraying the water around with enough pressure.
For low water pressure, try to clean the screen at the entrance of the fill valve, sometimes the fill valve can fail and not allow the proper water into the dishwasher and may need to be replaced. And, check the spray arm and pump cover for splits or leaks. Also make sure that the water is draining and is not accumulated in the dishwasher, if it is in dishwasher then check for clogged drain hoses and drain pump.
Low water fills are a very common trouble maker with today's dishwasher.
Please do rate this solution and revert for further assistance.
Thanks
Rylee
Dec 11, 2009 | GE Dishwashers
Dishes not getting clean
Check the following to address this issue.
1. No water
2. Not enough water
5. Not enough soap
Jun 19, 2009 | GE GLD4600NCS Built-in Dishwasher
Just a little water seems to be coming into the dishwasher and the dishes are not getting clean even on the Potscrubber cycle
1. No water
2. Not enough water
5. Not enough soap
Jun 06, 2009 | GE Dishwashers
Leaving gray white streaks and spots on dishes
Check the following to address this issue--
1. Not enough water
2. Clogged spay arms
3. Water temperature is too low
4. Not enough soap
Jun 01, 2009 | GE 25 in. Nautilus GSC3400J Free-standing...
Dishes are not clean.. on top level the dishes seem to be steamy
1. No water
2. Not enough water
5. Not enough soap
Jan 30, 2009 | Roper 24 in. RUD3000 Built-in Dishwasher
GE Max Dishwasher won't drain
I had the same problem with my GE Max model gsd6260k. I could hear it trying to drain and some small amounts of water going into the sink drain pipes but it never emptied it all there was aprox 1/2 inch of water that's 1.25 cm aprox for the metric lovers... lol
What i did was...Clean out all debris that was there.
There is a small basket (aka screen) just behind the bottom arms just a tad to the right i lifed it up enough to get a turkey baster into the opening (drain?). I coudn't seem to find the screws without taking all the bottom apart to get the basket out, as the water line going up the back to the center arms is there. Then i used the baster to remove water and i kept squeezing the air forcefully from the baster into the hole. This help, i don't know if it was a clog or what but i let the tub start to fill with water and then hit the start button again which makes it drain out. It was definately draining faster. when it finished there was no more water in the bottom of dishwasher.
Jan 20, 2008 | GE 24 in. Profile PDW9880JSS Built-in...
Dishwasher detergent does not dissolve entirely. Gel is still on side and powerball tabs doe not dissolve. Dishes are not clean. It sounds like it goes through the cycles properly.
1. No waterMake sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
2. Not enough water
5. Not enough soap
Dec 21, 2007 | GE 24 in. GSD3400G Built-in Dishwasher
GE GSD2200G02CC dishwasher
Your dishwasher probably has rotating blades on the top and bottom that spray water on the dishes.  Clean these off and make sure the holes are not clogged.
Sep 14, 2006 | GE GSD2200Z Dishwasher
GE 25 in. Nautilus GSC3400J Free-standing Dishwasher Logo
120 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
