Question about HP Pavilion dv1000 Notebook
DVD/CD writer Will read DVD discs but will not read CD discs.
  • 85 Answers
Re: DVD/CD writer
This is a common problem on HP laptops. Try updating the firmware on the DVD drive by searching on the web for the make and model number of the HP laptop and going from there.
Good luck...
Posted on Nov 16, 2007
0 characters
3 Points
Trying to create back first disc 100% burnt but cant eject to put in another
Go to My computer, right click the cd/dvd writer, and choose 'Eject',
if it wasn't get out, so you need to use tall needle softly inject it in the hole near the cd/dvd writer light and press it inside softly, then the cd/dvd writer will be ejected.
Take care, use the needle carefully.
Please tell us your results
Good Luck
May 13, 2011 | PC Laptops
My cd writer is not working can nort burn the disk what should i do i have a dell d800
Your cdrom drive can read a data disc or play cd audio? Check if its CDR/CDRW not DVDR/DVDRW, buy a disk cleaner and play it on your cd/dvd drive. After that try to burn again.
Nov 12, 2010 | Dell PC Laptops
Trying to copy some pics onto a cd to get some disc space but my drive wont recognise the cd rw
do you have a cd writer or rom drive is the first thing you have to check, if it's a writer then put the disc in first and it should give you an option to write files to cd accept then follow the the instruction to add your files, assuming your running windows. iif that does'nt work check to see if your discs are + or - it may be your wriiter will only accept one kind
Mar 26, 2010 | Compaq Presario V4000 Notebook PC
Dvd writer will not burn disc images, it will burn all other types ie music cds, data dvds, file backups, cant find name of dvd writer to get firmware update
Usually, you need software to read an 'ISO' disk-image file, and to decode the file, and to burn to a CD/DVD,
e.g., "AShampoo Burning Edition 6" is a free download from that will do the task.
Click Start
Click Control Panel
Click Classic View
Click System
Click Hardware
Click Device Manager
Select and expand the CD/DVD branch of the tree.
Double-click the CD/DVD drive.
Click Details to dislay the name/model of the device.
Nov 14, 2009 | HP G70-250us Notebook
New dvd writer recognised as old
Go to Control Panel.
Locate System.
Locate your Device Manager.
Under your DVD/CD Rom devices, locate the old DVD writer. Select it. Right click and hit Uninstall.
Now scan your computer for new hardware, and install the new DVD writer with the discs it comes with, if any.
Nov 07, 2009 | PC Laptops
I can not be abel to read writed CD
These discs that are written on other systems, were they finalized or are they multi-sessions discs that have been left open? Some drives have difficulty dealing with multi-session discs created by other drives. By telling it it is OK to format the CD, it is writing a new TOC (Table of Contents) that is blank since it did not see anything on the disc previously (so it didn't know there was anything to carry over from previous sessions). Now all other drives that try to read this disc are now reading an empty TOC and figure it is a blank CD.
You can try writing a disc on another computer and making sure it finalizes it, then try reading it with your laptop. You can also try to burn data to a CD on your laptop making sure the disc is finalized and try to read it on another computer to verify these suspicions.
Apr 06, 2009 | Lenovo 3000 N500 Notebook
DVD writer not working
Let's make sure that Nero is not causing the problem. Try this:
-Insert a blank CD or DVD
-Find a file that you want to burn to disc
-Right-Click on said file and select Send To --> DVD-RW Drive (D:) (or whatever your recordable drive is labeled)
-Open My Computer, double click on your recordable drive
- You should see your file ready to be burned to disc
- In the left-hand panel, you should see a link that says "Burn these files to disc" or something similar - click this link and see what happens
If this process works and properly burns a disc, your issue is not with your drive but with Nero. If this process does NOT work, then you may need to reinstall drivers for your DVD writer or replace the drive if it is faulty.
Hope this helps. Please take a moment to rate this solution. Thanks.
Mar 11, 2009 | Compaq 6710b Notebook
Dvd rome is not write the cd or dvd
you have dvd rom
it can only for read cd and dvd
dvd combo
it can only read cd
write cd
read dvd
dvd writer
it can read/write cd and dvd
Jan 24, 2009 | Lenovo 3000 Y410 Notebook
Dvd writer for toshiba satellite pro
HP dvd1040i 20x Super Multiformat DVD Writer
Price: $69.99
  Internal drive (double layer)
 Write speed: 8x double layer, 20x DVD±R, 48x CD-R
Rewrite speed: 8x DVD+RW, 6x DVD+RW, 32x CD-RW
Read speed: 16x DVD-ROM; 48x CD-ROM
Lightscribe disc-labeling technology
one-year limited warranty....
HP dvd1040e 20x Super Multi DVD Writer
External drive (double layer)
  • •   Write speed: 8x double layer, 20x DVD±R, 48x CD-R
  • •   Rewrite speed: 8x DVD+RW, 6x DVD+RW, 32x CD-RW
  • •   Read speed: 16x DVD-ROM; 48x CD-ROM
  • Lightscribe disc-labeling technology
    Price: 109.99
    These are the best DVD writers....
    Lightscribe technology is where you can burn your pictures on the disc as a label..... This is Hp's latest technology
    Oct 22, 2007 | PC Laptops
    HP Pavilion dv1000 Notebook Logo
    69 people viewed this question
    Top HP PC Laptops Experts
    Brian Sullivan
    Brian Sullivan
    Michael Thomas
    Michael Thomas
    Are you a HP PC Laptop Expert? Answer questions, earn points and help others
