Sounds like you don't have the tuner wired properly, IF you have a stand-alone tuner, then you need one wire to a continuous 12VDC for memory, the other 12VDC that's hot in accessory position, and then the ground. IF you hook the two 12volt wires together and they're only on when the car's on, then you will lose your memory of what channel it's on. Also, when you turn the radio off, turn it off with the BUTTON - not just by turning off the car. Give it a try using the radio's POWER BUTTON for on and off, NOT just the ignition, then it will remember the channel most of the time. Okay?
Press and hold volume up and power button at the same time to do a reset and to power down. You need to update firmware from the XM website to your unit and then do a master reset. contact Delphi by phone for deatailss lon how to reset and update firmware. Do not use a card larger than 2GB either.
I have same problem and sure connect did not help. The unit works fine otherwise except will not send a signal to my car radio. I will try removing the battery today & if this does not work I will do t paper clip reset in the battery compartment.
Remove back cover. Plug DC adapter into the bottom of the radio. Use an extra small paperclip or pin to push the 'reset' button just to the left of the white battery. Report back on progress.
Channel 210 is MLB Home Plate, which is part of the "Best of XM" package. If you haven't subscribed to Best of XM, which costs extra on top of your Sirius base subscription, then you cannot receive that channel.
Additionally, only certain radios are "Best of XM" compatible.. The fact that your car is a 2009 model.. While I don't know what radio it has in it.. I would assume it is a newer model radio that does have Best of XM capabilities, so the problem is most likely that you do not have the Best of XM package.
