Hobart 24 in. LXIC-5 Built-in Dishwasher
Problem for Hobart 24 in. LXIC-5 Built-in Dishwasher
Lx30h hobart dw. booster will not turn on. element
By xx5577 on Jul 04, 2009
lx30h hobart dw. booster will not turn on. element good,hi-limit is good, changed temp probe, still no power to contactor
Best Solution
posted on Aug 08, 2009
Very Helpful)
paultech8226
Rank: Guru
Rating: 93%, 13 votes
The booster heat control circuit is controlled by the relay board. Visually check for loose or burnt relay contacts...
You will see the booster LED light when it calls for heat. Some newer machines have a second high limit on the right hand side of the booster tank.
It may be your control board is configured for low temp with no booster. When you power up, the display should say LX30H. If not
Pull open the upper drawer, place a magnet over the door interlock switch.
CAUTION, 220 volt power is present. be carefull what you touch.
on control board, short J5-1 and J5-2, then power up. You are in factory setup. press select on the control board to see each option on the front panel., press up arrow on control board to step up through options for each step. when done, press the off button on front panel. remove short and start up normally. With the magnet in place, AND THE DOOR CLOSED, run the machine and observe the relay board status lights.
If you want to adjust the temp set points, with the machine off, press and hold the hidden key behind the front panel logo, and press select on the control board.. Or on power up, hold the wask key..Same to adjust options as above. Press off to exit.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Hobart 24 in. LXIC-5 Built-in
Questions and Unsolved Problems for Hobart 24 in. LXIC-5 Built-in
Do you recommend Hobart 24 in. LXIC-5 Built-in Dishwasher?
Answer
Answer
The machine shuts off as it is filling. This is a randomly occurring problem. We will use the... (More)
Answer
LX-18 Hobart need 2 detergent pumps. Can I buy these aftermarket or must they come from hobart
Answer
hobart lx18 no power to detergent pump, during the wash cycle there is no power present at the... (More)
Answer
Temperature in our sanitizer only reaches 90-95 degrees instead of 165. What could be the problem ?
Answer
I think my machine may be programmed for the 6% hypo-chlorite sanatizing solution and my supplier... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Hobart 24 in. LXIC-5 Built-in...:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 1581
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 905-9505
A&E Factory Service is a nationwide leader in...
A&E factory service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
