SOURCE: vz800 stalls when put in gear
Have a look at the side-stand micro switch, mounted on the frame, flush it out with WD40 or something similar ............ Let us know how you get on.
SOURCE: Engine stalls when engage in any gear from neutral.
CHECK THE SIDE STAND SAFETY SWITCH IS OPERATING
SOURCE: 400 Eiger ATV, starts and runs fine, stalls the
If 2 stroke check crank seals, check plug cap for proper resistance,check for good fuel flow to carb.Spark should jump at least a 1/4" gap,NOT JUST the .030 or plug gap.
SOURCE: my 1994 suzuki intruder starts but as soon as you
loose or broken ground wire ,could be broke under insulation, vibration of motor makes it lose contact. probably on gear indicator switch.
SOURCE: i recently had my wiring
When too much fuel is being supplied to the carburetors the engine is flooded. When you remove the spark plugs it allows the fuel to dissipate enough to allow the engine to run again. Drilling out the jets is not an accurate/preferred method for changing the jet size. Most of the time the jets end up being drilled too big. You can save money by just buying main jets. A jet kit usually will come with the slide needles made with a different taper from the stock needles. You may need to break down and buy a jet kit or a least replace the main jets with accurately sized main jets (not drilled out jets). In other words your main jets are just too big.
