How do you can press the rear wheel cylinders?
SOURCE: 94 S-10 Chev Brake problem
This is an easy fix un plug the abs sensor from spindle abs light will come on but the brakes will work only abs will not
SOURCE: elantra rear brake replacement
hiya the rear disc brakes are as front disc brakes auto adjusting however the rear brake calipers pistons have to be wound back into the caliper to enable new pads to be fitted if you look at piston you will see they have either slots or holes in the surface this is for a sutable implement/tool to fit and then turned clockwise whilst pressing piston as you wind/rotate it back into caliper for your info there is a tool made for this purpose made by draper or seeley tools which makes job easy diy and cost £9--99 uk and can be bought from most auto stores ? however it is possible to manage with the spanner with horse shoe open end commonly supplied with circular hand saws the spanner is the one used for replacing blade? i have used this in past with success but now have the expensive univesal tool for the job hope this helps?
SOURCE: rear brakes scrubbing on 1998 chevy venture van
Removal Procedure
Tools RequiredJ 38400
Caution: Keep fingers away from rear brake shoe springs to prevent fingers from
being pinched between spring and shoe web or spring and backing plate.
Installation Procedure
Notice: Do not over stretch the adjuster spring. Damage can occur
if the spring is over stretched.
Important: Ensure that the adjuster (2) engages the brake shoes (4 and 5), the
park brake actuator (3), and the adjuster actuator (1) properly.
SOURCE: how to install rear brakeshoes
REMOVAL & INSTALLATION
If
you are not thoroughly familiar with the procedures involved in brake
replacement, only disassemble and assemble one side at a time, leaving
the other wheel intact as a reference.
1983-88 Vehicles
See Figures 1, 2 and 3
CAUTIONBe careful that the springs do not slip off the tool during removal, as they could cause personal injury.
Fig.
1: Place the brake clamp tool over the ends of the wheel cylinder, then
remove the shoe-to-anchor springs using the correct tool
Fig. 2: View of the drum brake components-1983-88 9-inch brake shown
Fig. 3: View of the drum brake components-1983-88 10-inch brake shownTo install:
CAUTIONBe careful to make sure that the spring does not slip off the tool during installation, as it could cause injury.
SOURCE: 2001 dodge neon rear drum removal wheel cylinder
You need a pullers to get it off.But if your lucky putting a screwdriver between the drum and back-plate and pize it when your hitting with a hammer it may come off.good luck.
