Home | Fisher and Paykel | Fisher&Paykel Laundry: Fisher&Paykel Washer | Ecosmart washer sto...
Fisher and Paykel Fisher&Paykel Laundry: Fisher&Paykel Washer
Problem for Fisher and Paykel Fisher&Paykel Laundry: Fisher&Paykel...
Ecosmart washer stops with a full tub of water.
By pmondor on Jul 04, 2009
I'm getting some humming but it can't go into the spin cycle. Where are you getting these error codes?
Best Solution
posted on Aug 02, 2009
Very Helpful)
speirse
Rank: Master
Rating: 99%, 8 votes
Hi there
first turn the machine off then tilt the machine back and lean it on something(a chair or wall), look underneath, in the top right hand corner of the plastic outer boul you will see a small pump motor it has a fan on it spin this fan and if it is hard to turn that means there is somthing stuck in the drain pump keep turning the fan and try to free whatever is stuck in the pump, then try the machine on spin again all goin well the object in the pump should come out with the drain water( doing this will not harm the machine) if the object is still stuck you will need to get the water out of the machine (bailing or siphioning will work) and tilt the machine back again and take the wires off the pump and there should be a white tab in the boul holding the pump on pull this tab and twist the pump anticlockwise about a quarter turn(you will need a few towels or a boul or bucket to catch the water) and it should come off exposing the blockage.
Hope this solves your Problem.
Nick
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
posted on Jul 21, 2009
Not Rated)
dustymirror
Rank: Wiz
Rating: 90%, 21 votes
"sounds" like your drain pump is bad, or impeded. There may be something blocking the impeller but either way you will need someone out to look at it.
Was this helpful?
Yes
No
Popular Solutions for Fisher and Paykel
Questions and Unsolved Problems for Fisher and Paykel
Do you recommend Fisher and Paykel Fisher&Paykel Laundry: Fisher&Paykel Washer?
Answer
Answer
I have a fisher and paykel 601 smartdrive, it will not start, no lights come on, have spare parts... (More)
Answer
hi,i have 5.5 smartdrive 9 excellence washing machine,it was alright,until i was about to start the... (More)
Answer
F & P Smartdrive 708 has all lights showing when powering on, but will not start wash cycle.... (More)
Answer
Had the same problem after a severely unbalanced load caused the washer to basically stop in the... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Fisher and Paykel...:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14193
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
