Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
Lg washing machine pedistals
How do I remove the drawer from the pedistals for leveling the machine. It vibrates during the spin and I don't know how to remove the drawer to get in to adjust the levelers. Thanks
  • 1 more comment
  • Anonymous Dec 05, 2007
    The machine got off balance and started shaking real bad. I turned off the machine and tried to pull it out from the hole it was in. When I moved the machine the back leg dropped and I can't figured out how to put it back in place. I don't think anything broke. There should be a simple solution. Please help. I have a super capacity top loading washing machine, Model # LSR7233EQO. The machine is 10 years old.
  • Anonymous Dec 19, 2007
    the solution for lifting the washer didnt help me. I still need to know how to get the drawer out of the pedistle so i can get to the levelers to level the machine? Thanks
  • winekuhler Mar 06, 2008
    I have a Maytag Performa Top Load washer,when it goes into spin cycle it shakes all over the place. My wife says that her mom had a washing machine do that before and it needed a new belt,could this be true? If not what could it be,the belt looks fine and the washer is only 4 or 5 years old. Is there a weight or balance that could have come off? The bottom says something about a spring with 200 pounds of pressure on it, is the washer safe to take apart?I could use some mechanics help. THANKS
You will have to have the washer lifted to screw the leg back into the bottom. As far as the shaking...try some vibration isolation pads. www.keshakeaway.com the best $30 i have ever spent.I have a front loader on a pedestal also..it vibrated the pictures of the wall in the next room. with the pads I hardly know its running.( and the drawer stays shut)
Posted on Dec 18, 2007
LG front loaded washing machine vibrates during
If its on a pedistal then that will raise your center of gravity and cause the unit to be less sturdy during a spin. It could also be due to a weak floor. You may want to try a product called "shake away pads". The probably sell them at like home depot or lowes. They will run you about 40 bucks but they just go under the legs and help absorb some shock. Good luck _MJ_
Apr 27, 2010 | LG WM2487H Front Load Washer
Experiencing extreme vibration and noise with my LG WM2101H...sounds like a rocket is taking off everytime i wash something...it's on a pedestal, overflow pan and is located on the second floor...no...
This is actually pretty normal for newer LG front loaders. They've done a lot of work to isolate the vibration and noise from the spin cycle, but the higher RPM's have countered those improvements. Unless the manufacturer/technician can determine that something is actually wrong, you're probably going to need to install an anti-vibration pad under the washer pedistal to absorb most of the noise. It is very likely that the subfloor is actually amplifying the vibration into the "rocket" noise that you are hearing. Try installing Silent Feet anti-vibration pads or similar to prevent this amplification of the noise and vibration.
Mar 04, 2010 | LG WM2101HW 4.0 cu.ft. Washer
During spin cycle, washing machine is bouncing around the room
Sounds like the drum, balance weights have come off, to me. This will cause those symptoms.
Feb 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer is "walking" during the spin cycle
I have the same Duet that vibrates heavily during spin cycle. Leveled the unit with no success (our unit is mounted on the high base). Long story short, I went to Lowes and purchased a package of 4"X5" self stick foam rubber pads called Grippers by Wasman Consumer Group and paid a low price of $3.50. Since the washer walked forward, I cut one of the two Pads in the package in half, removed the sticky side paper protector and centered a half, sticky side to washer pad, to each front washer pad. The problem was solved.
I made sure the round floor pads of the washer were tight and the unit was level before attaching the Grippers. Hope this helps.
Jan 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Vibration during spin cycle
Unless your front loader is set firmly on concrete and leveled to perfection, the force of a heavy wash load spinning in excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
Also due to the earlier movements during the spin cycle, the shocks that are used to dampen the spin cycle might have been broken or damaged.
If the problem persists inspite of proper levelling, please do check for the shocks or might have them replaced them for good.
Dec 13, 2008 | LG WM2688HWM TROMM SteamWasher
I have a Whirlpool front load washer wfw8400tw02. I have had 2 service calls to checkout the out of balance condition. The first tech moved a drain hose inside the machine. The second one tried leveling...
being level is not quite as important as being solid on floor or on solid floor..if on a pedistal remove bottom drawer and be sure all mounting screws are tight ..with drawer adj all legs up until they are up tobottom of pedistal ck washer by trying to rock if movement detected adj FRONT feet only as much as needed to reduce motion ..same applies without pedistal if is a noise issue more than an unbalance issue suspect shocks supporting tub try removing bottom panel and being careful allow unit to run and try with one hand to isolate which shock..changed 1 friday
Dec 08, 2008 | Whirlpool Washing Machines
LG WD-8074FHB frontloader washingmachine, vibration during spinning
As happened to me, it could be that one of the shock absorbers at the base of the unit has come adrift from its securing point.
Jun 23, 2008 | LG Washing Machines
Walking Washer
due to weight and normal motion during wash/spin a very sturdy floor is necessary under front loads also some floors are a little slick and sliding may occur ck for weak floor and maybe some kind ok rough cushion under feet to reduce sliding also if on pedistals even more vibration may occur be sure all screws in pedistal are secure usually 4 from top onto bottom of washer also adj legs to lower unit as close to floor as possible and tighten lock nuts
Apr 25, 2008 | LG WM-2277HW Front Load Washer
Whirlpool duet sport..vibrates during spin and "walks"..on pedistal.sitting on tile
I just bought this washer and had two problems with it. 1 the vibration at medium spins and 2. a squeeking spring (every time the drum rotates a little squeek, but when spinning the squeek sounds constant.
What I discover in solving both my problems with the same solution. I had to ensure all 4 feet well on the ground and that the top of the washer was perfectly level. At one time I was out only about 2 mm on one side, but the bubble was slightly to one side on the level but still in between the level's markers. I tested with a load, and both problems were still there. Turn feet 1/2 turn on the side needing adjusting. Ran another load and you guessed it, no squeak, no vibration, spinning was quiet, I had to go over to check to see if the machine was going through the cycles. I couldn't believe that a few millimeters could make such a difference.
Now I am pleased with the performance, not to mention how clean the clothes are and the savings on water and drying.
Feb 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
383 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
