Panasonic KX-TA308 Phone Logo
A
Anonymous Posted on Oct 01, 2014
<!-- from fixya rte -->Unable to dial from normal phones in kxta308 - Panasonic KX-TA308 Phone
3helpful
I need instruction manual to program speed dial
I was unable to locate a user manual for that particular device, however the basic instructions for programming speed dial functions are normally very similar between most phones.
Generally there are ONE TOUCH Speed Dial buttons labelled something like M1, M2, and M3 on the dial pad somewhere.
There should also be another button labelled PROG or STORE on the keypad as well.
Normally to program a number into a ONE TOUCH speed dial memory location you carry out the following procedure:
Lift the handset.
Then press the PROG (or STORE) button.
Now just use the number keypad to dial the full telephone number that you want to store in a Speed Dial location.
Once the full telephone number is dialed, then push the M1 button to store that phone number in the M1 One Touch Speed Dial location.
The phone may or may not show some kind of confirmation that the M1 location was just programmed, then just hang up the handset.
Now when you lift the handset and press the M1 button, the phone should automatically dial the phone number you programmed into it.
Now just repeat the same process for the M2 and M3 One Touch Speed Dial buttons with other phone numbers if necessary.
To change one of the Speed Dial numbers, just carry out the normal programming procedure for that location using the new phone number and the old number will simply be overwritten.
I truly hope that was helpful to you.
Good luck and take care.
Joe.
8helpful
Panasonic 308 easa-phone manual
It is one of these two links, not sure which
http://service.us.panasonic.com/OPERMANPDF/KXTA308.PDF
http://service.us.panasonic.com/OPERMANPDF/KXTD308.PDF
I hope I have been of help but please do not hesitate to ask if you have any further questions.
Feb 21, 2011 • Cell Phones
2helpful
2answers
Panasonic KX-T7433
These phones are digital proprietary telephones which means that they only work on panasonic telephone systems and not on normal analog lines. If you have a panasonic system the correct way is to plug the line into the " To Main Unit ", the handset into " Handset/Headset" and a normal analog phone into " To Tel ". If the wiring on the line jack was not done digitally the phone will also not work
Kx-ta308
thank you for your car
i solve the proplem withe my frind
thank again
alkhaattbi
1helpful
2answers
Unable to connect voice dial
Hi marrick,
Voice Dial:
Important: Be sure your phone supports the voice dialing function andthat it is activated. Record at least one voice tag. (Please refer tothe instructions in your phone’s user manual.) Note: Voice dialingentries must be stored in the phone’s memory, not on the SIM card!
1. Press the Accept Button (1) for 1 second.
2. A voice dial beep will be heard on the kit to prompt the user to say the voice
tag of the contact to call.
3. Say the voice tag exactly as how you recorded it.
4. The voice will be played back to you, and then the phone will dial the number automatically.
Her's a .pdf file of the user manual, which you can save to your computer:
http://www.blueantwireless.com/downloads/supertooth_light/supertooth_light_manual.pdf
Hope this helps :)
Season's Greetings!
Chris (ziraffa)
Con
hi sumoto,
to activate your radio, you have to go through system programming
and activate the external music feature....
2answers
U600 unable to dial number
typed *2767*3855# this should manu reset the entire main-board.
Unable to find Voice dial for bluetooth carkit
in your settings you have car setting try there first
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
2helpful
Display contrast needs adjusted
press speaker button and dial 602+ up and down key to adjust the display. dial 601 to increase ring volume. DJ
Top Panasonic Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
