Question about Viking 31 in. VGSU101 Gas Cooktop
Viking cooktop disassembly
I can't get inside this thing to work on it! Is it welded together? Needs either new ignitor switches or module or ignitors, but I can't even get it apart to troubleshoot it. I'm pretty mechanically inclined, do most of my own work, but this is throwing me. Did I miss something easy?
  • 2 more comments
  • slednerd Nov 12, 2007
    Ok, unscrew the brass rings in the middle of the burners. They have two small opposed notches to put some kind of something in to turn them counterclockwise. I used a couple of putty knives and a gasket scraper like spanner/screwdrivers. This gets me apart. BTW, make sure you remove the cooktop before you disassemble...if you release the top with it in the countertop, it will fall through (no, I didn't do this, but almost).
    Now, my switches all check out, and I know the spark module why does it try to ignite continuously? Is it one of the piezio elements? This is a different topic, so I'll post it separate.
    Thanks for the fix,
  • JonF Dec 06, 2007
    My cooktop did the same thing, with some add'l info:
    The smallest burner stopped igniting, while all the others continued to work. That went on for months.  Then the sparker stopped working and the sharp sound heard with each spark was significantly diminished.  Then, for less than a day, the remaining burners returned to working again. Now, nothing sparks or makes a hint that it's trying to ignite.  Sounds like a repairman's dream...
  • Mike1964 Mar 09, 2008
    One day a fuse blew on my panel and I narrowed it down to the Viking VGSU161. When ever I plug it in it makes a loud snap sound and the fuse blows. Any ideas why? I was pulling it apart hoping to find something and figured the brass rings were the key, but I really would like to know what the solution could be too.
  • Anonymous Mar 08, 2009
    Spark module continuously tries to ignite. Spark module was toasted
    over time...(viking quality problem) .
    Found a distributor who sells viking parts made in China. I had one unit
    sent to me for 57 dollars and now only two burners ignite.
    Wonder why people bu viking...stick to GE or Maytag.
Well, it happened again. I'd replaced the spark module last time around, due to spillage getting into/onto that control unit. This time around, I had one burner that just kept sparking after it was lit. Cleaning the sparking post (emitter) didn't solve the problem, but I realized that there might be contamination elsewhere in the connect. I pulled the brass rings (nuts, really) and was able to lift the the top off. I carefully removed the individual sparking wires from each burner, and examined each assembly. After cleaning some debris off the male connector for that bad burner's spark assy, and reassembling the cooktop, it worked!
Things learned: The top can lift off without having to worry about dropping the entire unit. (This probably varies by model). The emitters _and_their_connectors_ are sensitive to contaminants. This was an EASY fix! Thanks for the helpful instructions everyone!
Posted on Dec 16, 2008
Here's the deal. Your spark module has gone out, for whatever reason. Gateway appliance has a great parts division, call them at 253-872-7838 and ask for parts. Order the spark module at least (about $45). If your's is like mine was, under the burner bases are orange o-rings. Mine were baked hard. Order all four new o-rings too. When it gets in, follow the above instructions for dissasembly. Inside, under a metal shield, covered by some insulation, is the spark module. The new module is slightly different, but has all the same connections. Go slow, and pay attention, but no big deal. Oh, BTW, you can pull the top without completely dismounting the cooktop from the counter top.
Good luck,
Posted on Dec 16, 2007
On top of each burner there is a thing you turn to the left to release each burner then the lid lifts off
Posted on Nov 12, 2007
Had the same problem some time back - turns out it was from accumulated food debris/buildup in and around the piezoelectric starters resulting in a change in resistance - which signaled the igniter to fire continuously. Try cleaning thoroughly top and bottom and make sure they are dry (I used oven cleaner, let it sit then cleaned w/toothbrush and toothpick.)
Good Luck
Posted on Nov 29, 2008
All six of the ignitors on my vgsu161bss cooktop are not firing--- electrical supply is working
Hi There are a few things to check for: First make sure the electrode (the small metal piece that the spark comes ...or The water that you spilled onto the cooktop has shorted out the ignition switch in the gas control knob. Don't worry .
Aug 16, 2011 | Viking 37 in. VGSU161 Gas Cooktop
The ignitor keeps sparking and won't stop.Do not
First of all, the model number is under the cooktop bottom, and secondly, this can happen due to the burner switches got wet somehow. Best thing to do is to unplug unit for 6-12 hours, allow to dry, then re-plug unit back in, this should be enough time to dry out the burner switches.
Good luck
Jul 13, 2011 | Bosch Cooktops
What causes gas igniter to keep clicking when gas is off
Sounds like someone washed down theb cooktop. If the moisture traveled throughout the contacts, the clicking sound will continue while off, until things dry out. Unplug cord from wall, give it some hours, maybe even a day or so, for moisture to evaporate. This worked for me in past. Give it a try. Good luck
Jul 30, 2010 | GE Profile JGP636 Gas Cooktop
Just solved this on the Kenmore model 911.33389 (same unit). Ignitors started with no one touching the cooktop. It has had a history of doing this and, this time, sparks were visible under the knob. Disassembled cooktop (don't forget to unplug and shut off the gas!). Performed "smell test" for burned electronics. Found smell in #3 ignitor switch. Disassembled and found worn, burned, and fried. Parts list was inside unit but had a typo for the "ignitor switch". Showed WB18T10240. Ordered that only to discover it was the transformer to ignitor wire harness set (no photo on website!). Wrong part... ugh! Dug deeper for the correct part #. It was WB18T10239 but it has been replaced with WB18T10344. Noted on some website that someone installed one and then the ignitor was NOT synchronized. Turns out, you can install WB18T10344 about three different ways. Mine was 22 degrees off vertical (different than original) and now my unit works perfectly! Also, install the new switch harness (if that's what you do) starting from the left front valve then clockwise. The original unit installed from the right front valve, then clockwise. Hope this helps.
Jun 20, 2010 | GE Profile JGP636 Gas Cooktop
Viking vgic3054-b left side burners do not spark right side fine
no to your comment.if all the wires look ok & the module is sparking change the wire from one that is working to the faulty one if still not working it will be the spark electrode in the burner.
Sep 14, 2009 | Viking 31 in. VGSU101 Gas Cooktop
Viking Burners keep on clicking! Anoying!
The causes to the clicking is that the ignitors could be wet, dirty (with grease caked on them or cleaning products or a bad spark module). The ignitors are the little white things on the side of each burner with a metal piece on top. If they are wet (let them dry out for 20 - 30 min on a high flame, if dirty sand the metal piece on top with sand paper or nail file. And if it is the spark module and u are technical, order one from the parts department for Viking. You will need ur model and serial # then find out if it is located under the burners or the rear of the range. There are several wires going to the spark module. Best way is to disconnect one by one and connecting it to the new box until all wires are switched from old to new module. Remember to unplug the unit before doing this because you may get shocked. Also if it is a sealed burner system that means that the burner bowls cannot be lifted from the range and water cannot seap under the burners then you could just change all 4 or six burner bases. Viking has adapted them throughout the many complaints and they are better now. Typical cost is: $350 - $400 if spark module is under burners, in rear = $500 - $600. Burner bases = 400 - 600 depending on number of burners and if it is with a venturi or screws. Good luck.
Aug 23, 2009 | Viking 31 in. VGSU101 Gas Cooktop
Viking professional 30 inch, sparking problem
If you have replaced the spark module with the new, blue PA020041 Tytronics 0+4 spark module, the physical positions of the leads that go to the burner igniters are reversed compared to the positions on the old, white module. Make sure that the switch wire for the burner and the position of the spark wire both go to the same burner! The positions are marked on the white label with green lettering.
Nov 25, 2008 | Viking 31 in. VGSU101 Gas Cooktop
Viking Gas Cooktop - Ignition sparks continuously when in 'on' position
This is likely caused by either a dirty ignition electrode, a cracked ignition electrode, or a bad spark re-ignition module.
Clean and inspect the six electrodes for cracks, If that doesn't solve it order a new
Ignition module from an internet appliance dealer that carries Viking parts like Appliance Zone.
If you replace the Ignition module yourself, make sure to turn off the circuit breaker to the range/cooktop before you work on it. Also, make a drawing of where the different color leads are plugged into the ignition module before you unplug the wires and plug them into the new re-ignitor. If the unit is under one year, this should be covered under the warranty.
Viking had a recall a few years back on their ignitor modules.
Jun 03, 2008 | Cooktops
Burners not lighting
I had the same issue and replaced the spark module myself, lots of wires and you have to make sure to label them before removal to be able to hook them back up correctly. To get to the module you need to unscrew all burners, no need to take the cover plate under the knobs. Burners remove by unscrewing center, brass nut. OEM spark module is VIKING RANGE #PA020021 U-67205-21. Go
od Luck
Apr 18, 2007 | Viking 37 in. VGSU161 Gas Cooktop
Viking 31 in. VGSU101 Gas Cooktop Logo
1,930 people viewed this question
Top Viking Cooktops Experts
Dan Webster
Dan Webster
Lawrence Oravetz
Andrew Taylor
Andrew Taylor
Are you a Viking Cooktop Expert? Answer questions, earn points and help others
